ID Deduplication on Append - UX #90546
2 Participants
Reference: blender/blender#90546
This task is about which behavior should be default when linking/appending IDs, and assets, and how much/how users should be able to customize those behaviors.
NOTE: Currently this is mostly listing topics to be discussed. This is also a first pass, there are likely many more use cases/topics to be discussed.
Problem
Currently, when appending a data-block, Blender appends (i.e. link and make local) the ID and all of its dependencies.
This means that if a single object in appended ten times, you will get ten copies of the object, but also of its meshes, materials, animations, etc.
This behavior may be fine in some cases, but not in others.
Default Behaviors
Generic Considerations
To avoid having many copies of the same ID, the first appended copy needs to be re-used for the subsequent appends.
Do we always re-use that ID, even if it has already been modified by the user locally?
Think first appended ID should always be re-used, reliably detecting modified IDs compared to linked one is possible, but tricky and not very efficient (RNA diffing)... There could be a mechanism though to break that reference such that next append creates a new copy of it. No diffing. User has ways to make an existing local ID not re-usable anymore, and to force not re-using an ID when appending again.
Could we use the UserPreferences settings for data copying, to decide which ID types we systematically create new copies for, and which ID types we try to re-use previously appended ID?Specific Cases
Here is a list of different use cases, possible behaviors being:
Append Material
Append Object
Append Collection
Collection itself:* In case of Empty-based instantiation:
*In case of ViewLayer-based instantiation: Object: same as above for Object case?
User Customization
Change behavior in UserSettings
Should user be able to change default behavior in user settings, or only on a case-by-case basis when actually linking/appending IDs or assets?
Change Behavior in Asset/File browsers
Should user be able to toggle options like "Link everything", or "Never deduplicate" ? etc.
Added subscriber: @mont29
Added subscriber: @Jeroen-Bakker
Efficiency depends also on how many times the code will be run. If the diffing process only runs once is a different store than running it multiple times. Updating caches also takes time and should be added into the consideration.
The mechanism could also be configured per operator. In D12116 I added a mechanism that could do this per operator in a generic way (not pushing this patch, just mentioning this for consideration).
