Addons: Blender import OBJ loose vertices #90665
5 Participants
Reference: blender/blender#90665
Operating system: Windows-8.1-6.3.9600-SP0 64 Bits
Graphics card: GeForce GTX 660 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 375.70
Broken: version: 2.93.2, branch: master, commit date: 2021-08-03 05:58, hash:
1eb06de260
If mesh have separate vertices with something else (edges, faces), blender ignores separate vertices.
It may be useful as pre-clean for scans, for example, but not as default behavior.
I expect, all recorded data should be imported to file.
To reproduce:
Export objects from file one by one to objs (1 file per object).
Import back, compare with originals.
v n e1.blend
2021-08-14_04-47-26.mp4
Added subscriber: @Vyach
Added subscriber: @1D_Inc
When we wrote our custom autocad to blender exporter via OBJ format (lines are exported as mesh edges and points as mesh vertices, layers are converted to separate objects, so layer name became object name), we decided to export pointclouds as edges connected to scene origin to bypass import issue.
This way after import we get pointclouds as vertices after deleting vertices in the scene's origin like that:
It would be nice if free vertices import and display problem will be solved, since pointclouds are used very often for architectural and engineering purposes, and pretty often there is no ability to make custom exporters, and there are not that much open formats which can handle free edges and vertices.
Added subscriber: @IyadAhmed
Added subscriber: @ideasman42
This is a limitation of the "Split" option which is enabled by default.
In OBJ vertices are global but faces and edges are tagged per object, so splitting geometry by objects looses loose vertices.
This is noted in the tool-tip and in the user manual, although the wording was not as clear as it could have been (now edited).
{rBM8320}, blender/blender-addons@763da384c5
Indeed, this is an OBJ format specification structurap limitation (it is a list of vertices, which are used for descripting objects geometry)
Is it possible to provide an solution, that will parse and import all the vertices, unused in geometry as a separate "Unused OBJ Verts" object, to have the ability to import everything that obj has, to avoid loosing it in case of a Split option?
If format has some readable data but unstructurized data, we would prefer to get it out from the original exported stucture, rather than to loose it.
Oh, I see. Weird stuff.
Totally agree with Paul, there should be option, that allows to import separate objects + all free vertices as one separate object. It will help in most cases to keep all data.
Want to clarify - unused OBJ vertices are not "unused data".
They are actually pointclouds, like LIDAR/laser scan or GIS data.
Those pointclouds are useful for generating [TIN surfaces ]], for example, using [ https:*blenderartists.org/t/addon-points-cloud-delaunay-triangulation-voronoi-diagram/541580 | Delaunay triangulation .
