crash when alt+LMB to change custom properties of different bones #90732
Closed
opened 2021-08-17 14:32:02 +02:00 by zyc17 · 11 comments
Operating system: macOS-10.14.6-x86_64-i386-64bit 64 Bits
Graphics card: Intel(R) Iris(TM) Plus Graphics 655 Intel Inc. 4.1 INTEL-12.10.25
Broken: version: 3.0.0 Alpha, branch: master, commit date: 2021-08-16 16:57, hash: 4dba206011
Broken version: 2.92
Worked: 2.83.17 (fb67495c7f)
I have two bones A and B, A has a custom property name 'a', B has none, in pose mode, select B and shift select A, press alt+LMB click and slide to change the custom property 'a', crash happens every time. If B has a custom property but with a different name, crash happens as well
I know this operation doesn't make sense, you can't change a property that doesn't exist on some of the selected objects, but sometimes irrelevant bones are selected unintentionally, and crashes are annoying, if properties don't exist just do nothing
  • Open .blend file
  • Select Bone A and add a custom property
  • Select bone B then {key Shift LMB} to select bone A
  • Edit custom property value with {key Alt LMB drag}
    #90732.blend
**System Information** Operating system: macOS-10.14.6-x86_64-i386-64bit 64 Bits Graphics card: Intel(R) Iris(TM) Plus Graphics 655 Intel Inc. 4.1 INTEL-12.10.25 **Blender Version** Broken: version: 3.0.0 Alpha, branch: master, commit date: 2021-08-16 16:57, hash: `4dba206011` Broken version: 2.92 Worked: 2.83.17 (`fb67495c7f`) **Short description of error** I have two bones A and B, A has a custom property name 'a', B has none, in pose mode, select B and shift select A, press alt+LMB click and slide to change the custom property 'a', crash happens every time. If B has a custom property but with a different name, crash happens as well I know this operation doesn't make sense, you can't change a property that doesn't exist on some of the selected objects, but sometimes irrelevant bones are selected unintentionally, and crashes are annoying, if properties don't exist just do nothing **Exact steps for others to reproduce the error** - Open .blend file - Select Bone `A` and add a custom property - Select bone B then {key Shift LMB} to select bone A - Edit custom property value with {key Alt LMB drag} [#90732.blend](https://archive.blender.org/developer/F10291364/T90732.blend)
Author
Added subscriber: @389150029
Member
Member
Thanks for the report. I can confirm on master.
Introduced between 4c26bb0232 and 48c8f9fc9a
(Can bisect but crash does not happen on ninja build)
Thanks for the report. I can confirm on master. ~~Introduced between `4c26bb0232` and `48c8f9fc9a`~~ ~~(Can bisect but crash does not happen on ninja build)~~
Member
Member
Added subscriber: @lichtwerk
Member
got a backtrace, but no additional info:
Program received signal SIGSEGV, Segmentation fault.
0x0000000000000080 in ?? ()
(gdb) backtrace
- 0  0x0000000000000080 in ?? ()
- 1  0x0000000004119d62 in RNA_property_float_get (ptr=0x7fffffffc890, prop=0x12dce400 <rna_PropertyGroupItem_double>)
    at /blender/source/blender/makesrna/intern/rna_access.c:3003
#2  0x00000000023e9f12 in ui_selectcontext_begin (C=0x60e000000048, but=0x61900077f688, selctx_data=0x6130005be190)
    at /blender/source/blender/editors/interface/interface_handlers.c:1842
#3  0x00000000023ef816 in ui_apply_but (C=0x60e000000048, block=0x6170001a7f88, but=0x61900077f688, data=0x6130005be048, interactive=true)
    at /blender/source/blender/editors/interface/interface_handlers.c:2234
#4  0x000000000240740b in ui_numedit_apply (C=0x60e000000048, block=0x6170001a7f88, but=0x61900077f688, data=0x6130005be048)
    at /blender/source/blender/editors/interface/interface_handlers.c:4186
#5  0x0000000002418c18 in ui_do_but_NUM (C=0x60e000000048, block=0x6170001a7f88, but=0x61900077f688, data=0x6130005be048, event=0x60d000488b98)
    at /blender/source/blender/editors/interface/interface_handlers.c:5389
#6  0x00000000024470ab in ui_do_button (C=0x60e000000048, block=0x6170001a7f88, but=0x61900077f688, event=0x60d000488b98)
    at /blender/source/blender/editors/interface/interface_handlers.c:7978
#7  0x0000000002456bb8 in ui_handle_button_event (C=0x60e000000048, event=0x60d000488b98, but=0x61900077f688)
    at /blender/source/blender/editors/interface/interface_handlers.c:9309
#8  0x000000000246f224 in ui_handler_region_menu (C=0x60e000000048, event=0x60d000488b98, UNUSED_userdata=0x6130005be048)
    at /blender/source/blender/editors/interface/interface_handlers.c:11332
#9  0x0000000000f8a4ce in wm_handler_ui_call (C=0x60e000000048, handler=0x6080000a4028, event=0x60d000488b98, always_pass=0)
    at /blender/source/blender/windowmanager/intern/wm_event_system.c:694
#10 0x0000000000fa1685 in wm_handlers_do_intern (C=0x60e000000048, event=0x60d000488b98, handlers=0x613000567598)
    at /blender/source/blender/windowmanager/intern/wm_event_system.c:2843
#11 0x0000000000fa29b0 in wm_handlers_do (C=0x60e000000048, event=0x60d000488b98, handlers=0x613000567598)
    at /blender/source/blender/windowmanager/intern/wm_event_system.c:2958
got a backtrace, but no additional info: ``` Program received signal SIGSEGV, Segmentation fault. 0x0000000000000080 in ?? () (gdb) backtrace - 0 0x0000000000000080 in ?? () - 1 0x0000000004119d62 in RNA_property_float_get (ptr=0x7fffffffc890, prop=0x12dce400 <rna_PropertyGroupItem_double>) at /blender/source/blender/makesrna/intern/rna_access.c:3003 #2 0x00000000023e9f12 in ui_selectcontext_begin (C=0x60e000000048, but=0x61900077f688, selctx_data=0x6130005be190) at /blender/source/blender/editors/interface/interface_handlers.c:1842 #3 0x00000000023ef816 in ui_apply_but (C=0x60e000000048, block=0x6170001a7f88, but=0x61900077f688, data=0x6130005be048, interactive=true) at /blender/source/blender/editors/interface/interface_handlers.c:2234 #4 0x000000000240740b in ui_numedit_apply (C=0x60e000000048, block=0x6170001a7f88, but=0x61900077f688, data=0x6130005be048) at /blender/source/blender/editors/interface/interface_handlers.c:4186 #5 0x0000000002418c18 in ui_do_but_NUM (C=0x60e000000048, block=0x6170001a7f88, but=0x61900077f688, data=0x6130005be048, event=0x60d000488b98) at /blender/source/blender/editors/interface/interface_handlers.c:5389 #6 0x00000000024470ab in ui_do_button (C=0x60e000000048, block=0x6170001a7f88, but=0x61900077f688, event=0x60d000488b98) at /blender/source/blender/editors/interface/interface_handlers.c:7978 #7 0x0000000002456bb8 in ui_handle_button_event (C=0x60e000000048, event=0x60d000488b98, but=0x61900077f688) at /blender/source/blender/editors/interface/interface_handlers.c:9309 #8 0x000000000246f224 in ui_handler_region_menu (C=0x60e000000048, event=0x60d000488b98, UNUSED_userdata=0x6130005be048) at /blender/source/blender/editors/interface/interface_handlers.c:11332 #9 0x0000000000f8a4ce in wm_handler_ui_call (C=0x60e000000048, handler=0x6080000a4028, event=0x60d000488b98, always_pass=0) at /blender/source/blender/windowmanager/intern/wm_event_system.c:694 #10 0x0000000000fa1685 in wm_handlers_do_intern (C=0x60e000000048, event=0x60d000488b98, handlers=0x613000567598) at /blender/source/blender/windowmanager/intern/wm_event_system.c:2843 #11 0x0000000000fa29b0 in wm_handlers_do (C=0x60e000000048, event=0x60d000488b98, handlers=0x613000567598) at /blender/source/blender/windowmanager/intern/wm_event_system.c:2958 ```
Added subscriber: @ChrisLend
Christoph Lendenfeld self-assigned this 2022-11-24 18:37:48 +01:00
going to look at that. still an issue in 3.3
Philipp Oeser removed the
label 2023-02-09 14:35:32 +01:00
stepping down from this since I couldn't fix it
Christoph Lendenfeld removed their assignment 2023-07-28 13:30:57 +02:00
Member
Will check
Will check
Philipp Oeser self-assigned this 2023-07-28 16:21:45 +02:00
Member
Fix in !112910
Fix in !112910
Blender Bot added
and removed
labels 2023-09-29 05:59:19 +02:00
Reference: blender/blender#90732
