there is no dxf import even after i enable it but is in export #90794
Closed
opened 2021-08-20 08:07:24 +02:00 by Pralhad Adhikari · 7 comments
M1 macbook mpro
Operating system: macOS
Graphics card: integrated m1
Broken:
(example: 2.79b release)
**M1 macbook mpro** Operating system: macOS Graphics card: integrated m1 **Blender Version** Broken: (example: 2.79b release) (example: 2.80, edbf15d3c044, blender2.8, 2018-11-28, as found on the splash screen) Worked: (optional) **Short description of error** **Exact steps for others to reproduce the error** Based on the default startup or an attached .blend file (as simple as possible).
Added subscriber: @Pralhad.ad
Member
Added subscriber: @lichtwerk
Member
Member
There are two Addons:
Do you have the right one enabled?
There are two Addons: ![image.png](https://archive.blender.org/developer/F10295704/image.png) Do you have the right one enabled?
Member
Member
Member
No activity for more than a week. As per the tracker policy we assume the issue is gone and can be closed. Thanks again for the report. If the problem persists please open a new report with the required information.
Reference: blender/blender-addons#90794
