Normal maps broken in master... again #90854
Closed
opened 2021-08-22 18:54:57 +02:00 by Steffen Dünner · 8 comments
Operating system: Linux-5.11.0-27-generic-x86_64-with-glibc2.31 64 Bits
Graphics card: NVIDIA GeForce RTX 2070 Super/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 470.57.02
Broken: version: 3.0.0 Alpha, branch: master, commit date: 2021-08-21 21:31, hash: 721fad37a1
Worked: All builds before https://developer.blender.org/rBb8ecdbcd964a7e78d7e077ef84a914b1374ae076
This is kind of a followup of my previous report https://developer.blender.org/T90776 that got fixed. But it looks like a new bug was born then.
Normal maps from image textures look very broken in final rendering while in preview they look like they should.
It took me a while to reproduce because at first I thought my normal map texture was broken or it was caused by its bit-depth (16 bit integer). But then I noticed that all kinds of normal maps show the behaviour.
  • Open the attached blend file. It contains one packed normal map as an EXR but the file format doesn't matter.
    Normal_Map_Bug_v02.blend
  • Press F12 to render
  • Here's a screenshot where on the left you can see the preview render and on the right the F12 render. There are two cylinders in each image. They have the same material except that the cylinder on the right also has a simple normal map.
    It renders more or less black, but the effect in production scenes looks like the normals look into a completely wrong direction, almost as if the color management was set to sRGB instead of non-color or something like that.
  • Eevee renders perfectly. Preview also looks fine.
P.S.: Upon further investigation I accidentally found out that normal maps work perfectly on objects with rotation 0,0,0. If I offset the rotation it looks like the rotation gets added to the shading normals somehow. The same goes for objects with applied rotations (0,0,0) that are parented to rotated objects. Like it happens very often when importing objects from other DCCs that use Y-up.
In the attached repro file you can confirm this by un-parenting the right cylinder and afterwards applying its rotations so that it gets reset to 0,0,0. Then it renders fine.
**System Information** Operating system: Linux-5.11.0-27-generic-x86_64-with-glibc2.31 64 Bits Graphics card: NVIDIA GeForce RTX 2070 Super/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 470.57.02 **Blender Version** Broken: version: 3.0.0 Alpha, branch: master, commit date: 2021-08-21 21:31, hash: `721fad37a1` Worked: All builds before https://developer.blender.org/rBb8ecdbcd964a7e78d7e077ef84a914b1374ae076 **Short description of error** This is kind of a followup of my previous report https://developer.blender.org/T90776 that got fixed. But it looks like a new bug was born then. Normal maps from image textures look very broken in final rendering while in preview they look like they should. It took me a while to reproduce because at first I thought my normal map texture was broken or it was caused by its bit-depth (16 bit integer). But then I noticed that all kinds of normal maps show the behaviour. **Exact steps for others to reproduce the error** - Open the attached blend file. It contains one packed normal map as an EXR but the file format doesn't matter. [Normal_Map_Bug_v02.blend](https://archive.blender.org/developer/F10306431/Normal_Map_Bug_v02.blend) - Press F12 to render - Here's a screenshot where on the left you can see the preview render and on the right the F12 render. There are two cylinders in each image. They have the same material except that the cylinder on the right also has a simple normal map. It renders more or less black, but the effect in production scenes looks like the normals look into a completely wrong direction, almost as if the color management was set to sRGB instead of non-color or something like that. ![image.png](https://archive.blender.org/developer/F10306436/image.png) - Eevee renders perfectly. Preview also looks fine. P.S.: Upon further investigation I accidentally found out that normal maps work perfectly on objects with rotation 0,0,0. If I offset the rotation it looks like the rotation gets added to the shading normals somehow. The same goes for objects with applied rotations (0,0,0) that are parented to rotated objects. Like it happens very often when importing objects from other DCCs that use Y-up. In the attached repro file you can confirm this by un-parenting the right cylinder and afterwards applying its rotations so that it gets reset to 0,0,0. Then it renders fine.
Added subscriber: @SteffenD
Member
Added subscribers: @kevindietrich, @Alaska
Member
Member
Can confirm with the provided file:
CC @kevindietrich as it seems to be related to your commits. b8ecdbcd96 seemed to be the cause for this issue, however a change to Blender/Cycles between now and then has changed the artifact scene. Most likely c0dd6f1164
Operating system: Linux-5.10.0-8-amd64-x86_64-with-glibc2.31 64 Bits
Graphics card: NVIDIA GeForce RTX 3090/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 470.63.01
Broken: version: 3.0.0 Alpha, branch: master, commit date: 2021-08-22 16:45, hash: b477333473
Can confirm with the provided file: CC @kevindietrich as it seems to be related to your commits. b8ecdbcd96 seemed to be the cause for this issue, however a change to Blender/Cycles between now and then has changed the artifact scene. Most likely c0dd6f1164 **System Information** Operating system: Linux-5.10.0-8-amd64-x86_64-with-glibc2.31 64 Bits Graphics card: NVIDIA GeForce RTX 3090/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 470.63.01 **Blender Version** Broken: version: 3.0.0 Alpha, branch: master, commit date: 2021-08-22 16:45, hash: `b477333473`
Added subscriber: @Dec
This issue was referenced by blender/cycles@7214f4c3d0
This issue was referenced by blender/cycles@7214f4c3d067044b705dce23fb8797ccf615d8fe
This issue was referenced by bffa168157
This issue was referenced by bffa1681577e3c850c4fbab5799612febf32a245
Kévin Dietrich self-assigned this 2021-08-24 01:46:30 +02:00
5 Participants
Reference: blender/blender#90854
