Spreadsheet editor doesn't update when changing active object #90914
5 Participants
Reference: blender/blender#90914
Broken: version: 3.0.0 Alpha, branch: master, commit date: 2021-08-24 18:38, hash:
5ef3afd87c
Worked: -
Spreadsheet editor is not updating when I change the active object if I use Viewer Node and have more than one geometry nodes editor open.
Open:
missing-notifier.blend
Alternate selecting between the plane and the cube.
See how the spreadsheet doesn't update until you mouse hover it.
Added subscriber: @dfelinto
Hi @dfelinto , I can not use this file with a little old blender versions.
Can say it does not update unless I hover over the Spreadsheet tab but this is something I am not able to reproduce with own created file
#90914.blend
Re-saved it uncompressed. As for your file you need to have a second geometry nodes editor for the bug to show.
Added subscriber: @lichtwerk
Was looking at this a bit (not sure it is a
).Notifiers seem to be OK here. But the Spreadsheet does additional checks to determine if a redraw needs to take place.
Problem is that
ED_spreadsheet_context_path_is_active
can often return true (this results in the Spreadsheet not being redrawn) when it checks against stuff in Node Editors on screen [most important issnode->nodetree != root_node_tree
]. And this in turn is caused by the Node Editors possibly being updated/drawn after the Spreadsheet is drawn (check whensnode_set_context
is called) -- so the Node Editors might not be "up-to-date" in regards to their current nodetrees. This can even be the case if only one Node Editor is on screen.Of course we could force-update the Node Editors at the time of checking in the Spreadsheet, but I assume this could be a performance killer:
P2346: T90914_snippet
Dont think we can control the order of Editors being drawn (that could be another solution)?
Stepping with a Debugger can even show this on a single Node Editor.
Added subscriber: @Calra
The fundamental problem here is that Blender just has no system to handle these kinds of update chains correctly. While I'm not 100% sure, I think the same fundamental problem is the cause for this thread: https://devtalk.blender.org/t/responding-to-selection-changes/15813.
I'm inclined to call this a known issue.
Will change this to a known issue. Here are some more details of why this is a bit tricky:
We don't have a real system to handle such update chains correctly as mentioned in the previous post.
Can not reproduce this anymore in 3.4 and following version.
I'll find the resolving commit. Maybe we would be able to backport it
Fixed with
c55d38f00b
Definitely we can not backport the commit so I'll just close this ticket :)
If anyone still able to reproduce this issue in latest master, please reopen it :)
