glTF light intensity requires unit conversion #91035
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
7 Participants
Reference: blender/blender-addons#91035
Operating system: Ubuntu Linux 20.04
Graphics card: RTX 2080 Ti
Broken: 2.93.3
Worked: None as far as I know
When point lights are exported to a glTF file, it looks as though the intensity is supposed to be expressed in candela . In Blender, the intensity is expressed in watts; presumably it's the amount of illumination you are supposed to get from an incandescent bulb of that power. Unfortunately no unit conversion takes place during export, so for example a 100W bulb in Blender will be exported as a glTF light of intensity 100 candela.
I hope this is helpful. If you need anything else please let me know, and thank you for your hard work on Blender!
Added subscriber: @PeteX-2
Added subscriber: @scurest
There is also a report on the addon's tracker: https://github.com/KhronosGroup/glTF-Blender-IO/issues/564
Added subscriber: @Grady
How is the conversion handled for non-point lights?
Sun lights, area lights, spot lights, what units should they be expressed in?
Added subscriber: @donmccurdy
Taking point lights as an example, I believe the conversion ought to go like this:
watts = blender_lamp.energy
LUMENS_PER_WATT = 683
PI = 3.14159
candela = watts * LUMENS_PER_WATT / (4 * PI)
For a 20W Point light, this produces 1087 cd. However, I've tested three different engines that all claim to do point lights in units of candela, and they're all consistently overexposed compared to the original Blender scene. In the test case I've got, 1cd produces a result much closer to the Blender original. But I don't have any way of knowing whether I'm just off by a constant factor here. I'm also a bit confused that the conversion table in the Blender documentation (see https://docs.blender.org/manual/en/dev/render/lights/light_object.html#power-of-lights) does not appear to use anything like the conversions above. It states that a candle is comparable to a 0.05 W point light in Blender. But the expression above yields .05 * 683 / (4*PI) = 2.71 cd. Any idea I'm missing here?
Added subscriber: @WCN
About this specifically, I think that's a red herring. "0.05" feels like the kind of number that's meant to give a ballpark estimate more than an exact definition. It might just be a big candle— Or a candle meant to show up better in renders that will inevitably be shown on low-dynamic-range monitors. Actually, if anything, I'd be inclined to interpret the fact that the conversion shifts the value by three (Base-10) orders of magnitude and still ends up at roughly one candela as a sign that the conversion ratio of 683 is appropriate for Blender.
May be worth pointing out too that the values in that table also all have vastly different conversion ratios from each other. The lowest ratio is
227
, and the highest is556
. Even between lights of the same type there is significant variation. To me that feels like an artist at the Blender Institute/Foundation arrived at those exact values through trial and error and copied and pasted them from their personal notes as a rule-of-thumb guide when they were writing the documentation.Added subscriber: @JulienDuroure
Fixed by
9d903a93f0
