Glare Filter Problem with Full Frame Compositing #91314
Reference: blender/blender#91314
Operating system: Linux-5.11.0-34-generic-x86_64-with-glibc2.31 64 Bits
Graphics card: NVIDIA GeForce RTX 2070 Super/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 470.57.02
Broken: version: 3.0.0 Alpha, branch: master, commit date: 2021-09-10 11:28, hash:
60cfdf0809
When switching the Compositor from "Tiled" to "Full Frame" the Glare node gives a wrong result when set to "Medium" or "Low".
The resulting glare looks like it's scaled down to half or quarter size depending on the quality setting. "Full" shows no problems.
If you set the quality of the Glare to "Low", the area that shows the effect is even halved
Test File:
#91314.blend
Added subscriber: @SteffenD
Hi, thanks for the report. I can reproduce this on master: .
b5a1c194c5dd
But unable to open the file with older versions (want to check if this is regression)
Also: I'm not quite sure if tracker is open for the experimental feature bugs.
Ah, my fault. I saved the blend file with compression enabled which now uses Zstd in master. I can re-upload the blend file again without compression or you could open it in master and re-save it with compression disabled so you can open it in older versions of Blender again.
Added subscriber: @lichtwerk
Hi, thanks for briefing. Reuploaded the file. Behavior is even same for older 3.0.0 builds (tested with:
4891da8ae2
, commit date: 2021-06-16)Hi @lichtwerk , I am not sure about this case. Can you please check this?
Reports on experimental features are OK.
This can be closed since
283d76a70d
has been committed. :)Changed status from 'Confirmed' to: 'Resolved'
OKi
