2 out of 6 bytes produced by BLI_rng_get_char_n() are predictable #91395
5 Participants
Reference: blender/blender#91395
Operating system: Kubuntu Linux 20.04 LTS
Broken: current master @
9fe6854a93
Worked: didn't check with older versions
seems to produce predictable bytes, regardless of the seed used.Exact steps for others to reproduce the error
Run this program a few times, and take note of the fact that the seed changes on every run, but the magenta columns stay the same between runs.
P2390: (An Untitled Masterwork)
I compiled this with
g++ -Wall -std=c++17 -o rng_test rng_test.cc -I ./source/blender/blenlib/ ../build_linux/lib/{libbf_blenlib.a,libbf_intern_guardedalloc.a}
, but I've seen the same behaviour using it to generate random bytes for generating UUIDs within Blender, so this shouldn't be caused by my simplified compilation options.This is a screenshot of the output I get on my machine (screenshotted so that the highlighted colums are maintained)
Proposed Solution
Fixing this issue would break a lot of things in existing files (e.g. layout of particles or hair, or patterns of procedural textures, etc.). Since there is no versioning possible here, this issue could be fixed in two steps:
_deprecated
prefix, but keep using it everywhere it is currently used in code.Added subscriber: @dr.sybren
4 out of 6 bytes produced by BLI_rng_get_char_n() are predictableto 2 out of 6 bytes produced by BLI_rng_get_char_n() are predictableAdded subscriber: @dfelinto
Added subscriber: @LazyDodo
The seed function expands a 32 bit value into a 64 bit one with the following code:
0x0000725f1ea2330e
0xXXXX........XXXX
void RandomNumberGenerator::seed_random(uint32_t seed)
this does a great job at randomizing bits 16..48 but "fixed" bits will still have their fixed values, which are reflected in the output of the RNG
Given there's many things relying on the behavior of this RNG it's not really recommended to change the seed function, however something like
constexpr uint64_t lowseed = 0x330E;
x_ = (static_cast<uint64_t>(seed) << 16) | lowseed;
x_ = x_ ^ static_cast<uint64_t>(seed);
would do the trick, The upper 16 bits being zero is not an issue since they are being discarded anyhow.
Unrelated, your initial seed selection based on time has some issues on windows where
sizeof(long) == 4
even on 64 bitshifting a 32 bit variable by 32 bits has some fun undefined behavior (5.8 from the C++ spec) where the result (not in spec, but all compilers do this) is the original value rather than 0 , leading to
ts.tv_nsec^ts.tv_nsec
which is.... 0 :)Added subscriber: @Raimund58
