Selection in the 3d view is broken in build from Xcode 13 #91680
14 Participants
Reference: blender/blender#91680
Operating system: macOS-11.6-x86_64-i386-64bit 64 Bits
Graphics card: AMD Radeon Pro 5500M OpenGL Engine ATI Technologies Inc. 4.1 ATI-4.6.20
Broken: version: 3.0.0 Alpha, branch: master, commit date: 2021-09-24 06:41, hash:
fc7beac8d6
Using the default keymap, clicking to select items in the 3d view doesn't work
Box select still works, but single clicking is broken. Bug also applies to the IC keymap.
Added subscriber: @WilliamReynish
#95464 was marked as duplicate of this issue
#94319 was marked as duplicate of this issue
#93041 was marked as duplicate of this issue
#91772 was marked as duplicate of this issue
Seems likely this could have been causes by
bffda4185d
ord431b91995
, or another recent keymap commit?Added subscriber: @PhlixFer
I have a very similar problem, though I still can select objects; it's just that the selection "hitbox" is offset from the actual rendered mesh. Strangely, selecting in edit mode still works as expected...
Blender version: 3.0.0 Alpha, branch: master, commit date: 2021-09-24 19:18, hash:
a3027fb094
Screen Recording 2021-09-25 at 08.48.48.mov
Added subscriber: @michael64
This bug is likely caused by the architecture independent stage -O2 optimization of the clang version 13 compiler that ships with Xcode 13.
I compiled Blender 2.93.0 with Xcode 13 and the same selection bug appears
so it's not caused by recent Blender source changes.
I compiled the most recent version with Xcode 13 for x86_64 and ran it via Rosatta and the selection bug appears as well so it is not an arm64 architecture issue.
Changing the optimization of only CMAKE_C_FLAGS_RELEASE from -O2 to -O1
in build_files/cmake/platform/platform_apple.cmake and recompiling makes the bug go away.
Bisecting between the optimized and unoptimized binary object files of the Blender I could locate the miscompiled file as source/blender/editors/space_view3d/view3d_view.c.
Leaving CMAKE_C_FLAGS_RELEASE as is at -O2 and adding
"#pragma clang optimize off" allowed narrowing down the miscompiled function to
be view3d_winmatrix_set in view3d_view.c.
This change works for me if you'd like to try:
I am not advocating to commit this patch to fix a compiler bug.
Compiling with Xcode 12.5.1 does not produce this error.
If somebody would like to report this issue with the clang project or file
a radar please do so.
The source of this bug could be found by compiling the Open Source
equivalent of clang-1205.0.22.11 from source then compiling
Blender with this clang and saving
build_darwin_release/source/blender/editors/space_view3d/CMakeFiles/bf_editor_space_view3d.dir/view3d_view.c.o
Compiling clang-1300.0.29.3 from source should result
in the miscompiled view3d_view.c.o.
Bisecting the clang sources and looking for the version
that produces the defective view3d_view.c.o should
give us the clang revision where that introduces the error.
If somebody wants to pinpoint the error in clang please do.
Maybe it is even fixed in the most recent clang development version.
If I am bored next Saturday maybe I'll do this myself.
Added subscribers: @ankitm, @mano-wii
From the description this appears to be a serious regression.
So I'm setting it as high priority even though I can't replicate the problem on an
Apple M1
withmacOS-11.5.2
. (At least with a build from the buildbot).@ankitm, could you confirm this?
@michael64 nice investigation,
if the problem is confirmed on other hardware and new clang development version doesn't solve it, i feel that we may have to apply the workaround for Blender 3.0.
Cannot redo on downloaded blender
c53ffda8a4
Intel i5, Intel HD 6000, macOS 10.14, nor on macOS 11.4, Radeon Pro 5300M.Added subscribers: @Robw, @PratikPB2123
Nice find. Indeed, builds from the buildbot appear to work correctly, maybe they are not using Xcode 13?
Selection in the 3d view is brokento Selection in the 3d view is broken in build from Xcode 13The buildbot for darwin uses Xcode 12.4 for x86_64 and arm64 at the moment which luckily does not produce the error for the daily build.
One can find the exact compiler and Xcode version in the generated stdout file of the compile-code stage (nr. 6).
The files from a daily build are https://builder.blender.org/admin/#/builders/31/builds/1858/steps/6/logs/stdio (arm64)
and https://builder.blender.org/admin/#/builders/9/builds/1892/steps/6/logs/stdio (x86_64)
A search for "compiler identification" currently yields:
A search for "Detected" yields the following:
I compiled with clang+llvm-13.0.0-rc3-x86_64-apple-darwin.tar.xz from LLVM project releases + Xcode 11.3.1 and don't see an error
Added subscriber: @ponderz
Confirming due to multiple reports.
Not a high priority IMO since an Xcode minor version upgrade might fix the issue & updating buildbot to Xcode 13 is not imminent. CC @ponderz
For a workaround, download a different Xcode from https://developer.apple.com/download/all/
Can confirm, compiling with Xcode 12.5.1 does indeed remove the object selection issue in the 3d view
Added subscriber: @adamhenderson
Added subscriber: @CharlesWardlaw
I was pointed at this ticket by @ankitm in the chat, and just wanted to confirm that I've hit the same issue (XCode 13.1). Going to try reverting.
Added subscriber: @Nurb2Kea
Using terminal with this https://wiki.blender.org/wiki/Building_Blender/Mac guide, always ends up without the ability to select.
I can't select the objet left, right, top, aside and direct. BUT I can select it when selecting it underneath itself.
Feels like that everything is abobe 0 can't be selected and vice versa.
macos 12.0.1, up to date brew, tried xcode 13.0 -13.1 used with blender builds 3.0 and 3.1
So after a long bit of downloading, unpacking, and experimenting: it's not possible on macOS 12 to revert to an earlier Xcode. =/ The command-line tools similarly will not install, claiming the OS to be "too new."
My next trick is to attempt a build with homebrew llvm@12, but the first attempts at that yesterday were disastrous.
@CharlesWardlaw See D12210: Use LLVM toolchain to get std::filesystem on how to use LLVM toolchain.
or if you don't want to modify source code, follow the steps to create toolchain and then use https://developer.blender.org/F9413084 with modifications for your system.
Tagging eevee & Viewport for an investigation in case our code is at fault.
Added subscriber: @AledBrown
Added subscriber: @Steve-Hanff
This issue was referenced by
8ca4d20878
98bb8e6955
39ebb8be4d
22cf8b9532
I commit a workaround now, thanks @michael64 for tracking down the cause.
Also backported to 2.83, 2.93, and put on the list for a potential 3.0.1.
Here is the terminal log from compiling blender on macos 12.0.1 Intel and Terminal and Xcode 13.1 with this guide https://wiki.blender.org/wiki/Building_Blender/Mac
When searching this log for 'warning:' you will find a lot. Not sure if that is right/supposed to be like that!?
The log is log, so juat search for 'warning:'
This is just for info on my/user side compiling.
Thanks in advance
compile log blender 7 dec 2021.txt
You can ignore the warnings, that's expected.
Though I'm not sure why that is relevant to this task, are you saying the problem still exists with the very latest master for you, or is it just an unrelated question?
This was a related question. I thought maybe the warnings coming up because of a misconfig of my workflow.
I just compiled it, and it works fine now. THX Brecht :-)
Just for Information on todays macos updates:
I updated to macOS 12.1, xcode 13.2 and brew. Two files where missing, but after new cloning into blender-git folder compiling went fine and all working. Even the former selecting issue.
xcode had to be installed manually because of an apple appstore issue.
Anyways it all works, here the files listed that where missing after only updating the OS and xcode and not blender-git folder.(Part of the log::)
In file included from /Users/NURB/blender-git/blender/extern/audaspace/plugins/openal/OpenALDevice.cpp:17:
/Users/NURB/blender-git/blender/extern/audaspace/plugins/openal/OpenALDevice.h:36:10: fatal error: 'al.h' file not found
include <al.h>
[ 19%] Building CXX object extern/audaspace/CMakeFiles/audaspace.dir/plugins/openal/OpenALReader.cpp.o
In file included from /Users/NURB/blender-git/blender/extern/audaspace/plugins/openal/OpenALReader.cpp:17:
/Users/NURB/blender-git/blender/extern/audaspace/plugins/openal/OpenALReader.h:31:10: fatal error: 'alc.h' file not found
include <alc.h>
[ 19%] Building CXX object extern/bullet2/CMakeFiles/extern_bullet.dir/src/LinearMath/btGeometryUtil.cpp.o
1 error generated.
make- [x]: *** [extern/audaspace/CMakeFiles/audaspace.dir/plugins/openal/OpenALDevice.cpp.o] Error 1
make- [x]: *** Waiting for unfinished jobs....
1 error generated.
[ 21%] Built target extern_ceres
make- [x]: *** [all] Error 2
make: *** [all] Error 2
@Nurb2Kea please post build issues at https://devtalk.blender.org/c/blender/building-blender/11
Added subscribers: @send2jithu, @lichtwerk
Added subscriber: @LuckyChris
