Selecting "Remove unused slots" in Materials panel removes slots that are assigned to particle systems/hair #91691
Closed
opened 2021-09-24 21:02:10 +02:00 by Nikhil Shringarpurey · 10 comments
Graphics card: NVIDIA GeForce RTX 3090/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 471.68
Broken: version: 3.0.0 Alpha, branch: master, commit date: 2021-09-24 14:03, hash: 95ec6e4dd3
Worked: never
In the Material panel in the Properties editor, there is a drop-down next to the material slots. Selecting "Remove unused slots" will remove materials that are assigned to particle systems/hair. So it seems unless material slots are assigned to at least one face, this function deletes their slots.
  • Add 2 material slots to the default cube - Slot 1: skin and Slot 2: hair.
  • Ensure the skin material is applied to all faces of the cube
  • Add a hair particle system
  • Under the Particle System's Render tab, select the hair material slot.
  • Render to ensure materials are assigned correctly.
  • Return to the material tab in the properties editor and click the "Remove unused slots" option from the drop-down
Watch the hair material slot be deleted.
or
  • Open .blend file
  • Switch Viewport Shading to Material Preview
In material Properties: Material Specials -> Remove Unused Slots
Test File:
#91691.blend
**System Information** Operating system: Windows-10-10.0.19041-SP0 64 Bits Graphics card: NVIDIA GeForce RTX 3090/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 471.68 **Blender Version** Broken: version: 3.0.0 Alpha, branch: master, commit date: 2021-09-24 14:03, hash: `95ec6e4dd3` Worked: never **Short description of error** In the Material panel in the Properties editor, there is a drop-down next to the material slots. Selecting "Remove unused slots" will remove materials that are assigned to particle systems/hair. So it seems unless material slots are assigned to at least one face, this function deletes their slots. **Exact steps for others to reproduce the error** - Add 2 material slots to the default cube - Slot 1: skin and Slot 2: hair. - Ensure the skin material is applied to all faces of the cube - Add a hair particle system - Under the Particle System's Render tab, select the hair material slot. - Render to ensure materials are assigned correctly. - Return to the material tab in the properties editor and click the "Remove unused slots" option from the drop-down # Watch the hair material slot be deleted. --- or - Open .blend file - Switch Viewport Shading to `Material Preview` # In material Properties: `Material Specials -> Remove Unused Slots` Test File: [#91691.blend](https://archive.blender.org/developer/F10585208/T91691.blend)
Author
Member
Added subscriber: @Nikhil.Net
Author
Member
This appears to be a shortcoming in the "bool BKE_object_material_slot_used(ID *id, short actcol)" function in material.c from what I can tell. I can work on a fix if others agree this behavior is not good.
Member
Member
Hi, thanks for the report. I think the option removes the materials which are not linked to any object.
Not quite sure if this is expected output. Will leave this for other triagers, developers to check.
Hi, thanks for the report. I think the option removes the materials which are not linked to any object. Not quite sure if this is expected output. Will leave this for other triagers, developers to check.
Author
Member
Thanks, Pratik. Yes, it currently only loops thru all MPoly's and all MFace's and checks if those have the material assigned. The real logic appears to exist in mesh.c at line 1447. The method is called "BKE_mesh_material_index_used(...)"
> In #91691#1225773, @PratikPB2123 wrote: > Hi, thanks for the report. I think the option removes the materials which are not linked to any object. > > Not quite sure if this is expected output. Will leave this for other triagers, developers to check. Thanks, Pratik. Yes, it currently only loops thru all MPoly's and all MFace's and checks if those have the material assigned. The real logic appears to exist in mesh.c at line 1447. The method is called "BKE_mesh_material_index_used(...)"
Added subscriber: @mano-wii
Apparently this operator only considers a material to be "used" if any face has the material assigned.
But the particles assigned to the object may be using the material, so it's technically being "used".
So I'm considering it as a bug, either because of the functionality or because of the Operator's description.
Apparently this operator only considers a material to be "used" if any face has the material assigned. But the particles assigned to the object may be using the material, so it's technically being "used". So I'm considering it as a bug, either because of the functionality or because of the Operator's description.
This issue was referenced by 6578db57cd
This issue was referenced by 6578db57cd878a94bdbdabe953c8819625c5a811
Bastien Montagne self-assigned this 2021-09-27 18:09:42 +02:00
Thomas Dinges added this to the 3.0 milestone 2023-02-08 15:59:02 +01:00
5 Participants
Reference: blender/blender#91691
