Crash snapping mesh if a beveled curve is present #91734
Closed
opened 2021-09-26 22:17:29 +02:00 by Georg K · 17 comments
Operating system: Linux-5.14.7-2-MANJARO-x86_64-with-glibc2.33 64 Bits
Graphics card: AMD VERDE (DRM 2.50.0, 5.14.7-2-MANJARO, LLVM 12.0.1) AMD 4.5 (Core Profile) Mesa 21.2.2
Broken: version: 3.0.0 Alpha, branch: master, commit date: 2021-09-24 14:42, hash: 4a2c63f4bd
Worked: 2.93
Apparently caused by 6a88f83d67
Blender will crash if you snap a mesh object in a scene that also includes a beveled curve object.
If you set the bevel depth of the curve to 0, the file will not crash. Trying to move and snap the curve does not cause a crash.
(In some earlier tests, it was necessary for the curve to have shapekeys, but the sample file crashes without. In some tests, changing the mesh geometry prevented the crash.)
In the attached file, select the mesh object,
  • hit G to move and hold Ctrl to snap
  • try moving the mesh object (does not move)
  • Blender crashes
Crash snapping mesh if a beveled curve is present.blend
From scratch:
  • In the default scene, add a Bezier curve
  • change its bevel depth
  • select cube, press G then hold down Ctrl
  • Blender crashes
output:
Segmentation fault (core dumped)
backtrace:
 Blender 3.0.0, Commit date: 2021-09-24 14:42, Hash 4a2c63f4bd7e
# backtrace
../build_linux/bin/blender(BLI_system_backtrace+0x33) [0x7d81613]
../build_linux/bin/blender() [0xf4773b]
/usr/lib/libc.so.6(+0x3cda0) [0x7fcafe0abda0]
../build_linux/bin/blender(minmax_v3v3_v3+0) [0x7d37b70]
../build_linux/bin/blender(BKE_mesh_minmax+0x42) [0xfb8df2]
../build_linux/bin/blender(BKE_mesh_boundbox_get+0x97) [0xfb8127]
../build_linux/bin/blender() [0x1e2aa08]
../build_linux/bin/blender() [0x1e2afdc]
../build_linux/bin/blender() [0x1e2782e]
../build_linux/bin/blender() [0x1e2ba5d]
../build_linux/bin/blender(snapObjectsTransform+0xab) [0x1e2604b]
../build_linux/bin/blender() [0x1e262fa]
../build_linux/bin/blender(applySnapping+0xa9) [0x1e24fa9]
../build_linux/bin/blender() [0x1e1bcc3]
../build_linux/bin/blender(transformApply+0x71) [0x1de4de1]
../build_linux/bin/blender() [0x1e1e56b]
../build_linux/bin/blender() [0x133f38c]
../build_linux/bin/blender() [0x13407a7]
../build_linux/bin/blender() [0x1340ddc]
../build_linux/bin/blender(wm_event_do_handlers+0x248) [0x1341348]
../build_linux/bin/blender(WM_main+0x20) [0x13372a0]
../build_linux/bin/blender(main+0x336) [0xec0616]
/usr/lib/libc.so.6(__libc_start_main+0xd5) [0x7fcafe096b25]
../build_linux/bin/blender(_start+0x2e) [0xf43e0e]
# Python backtrace
**System Information** Operating system: Linux-5.14.7-2-MANJARO-x86_64-with-glibc2.33 64 Bits Graphics card: AMD VERDE (DRM 2.50.0, 5.14.7-2-MANJARO, LLVM 12.0.1) AMD 4.5 (Core Profile) Mesa 21.2.2 **Blender Version** Broken: version: 3.0.0 Alpha, branch: master, commit date: 2021-09-24 14:42, hash: `4a2c63f4bd` Worked: 2.93 Apparently caused by 6a88f83d67 **Short description of error** Blender will crash if you snap a mesh object in a scene that also includes a beveled curve object. If you set the bevel depth of the curve to 0, the file will not crash. Trying to move and snap the curve does not cause a crash. (In some earlier tests, it was necessary for the curve to have shapekeys, but the sample file crashes without. In some tests, changing the mesh geometry prevented the crash.) **Exact steps for others to reproduce the error** In the attached file, select the mesh object, - hit G to move and hold Ctrl to snap - try moving the mesh object (does not move) - Blender crashes [Crash snapping mesh if a beveled curve is present.blend](https://archive.blender.org/developer/F10617539/Crash_snapping_mesh_if_a_beveled_curve_is_present.blend) From scratch: - In the default scene, add a Bezier curve - change its bevel depth - select cube, press G then hold down Ctrl - Blender crashes output: Segmentation fault (core dumped) backtrace: ```lines Blender 3.0.0, Commit date: 2021-09-24 14:42, Hash 4a2c63f4bd7e # backtrace ../build_linux/bin/blender(BLI_system_backtrace+0x33) [0x7d81613] ../build_linux/bin/blender() [0xf4773b] /usr/lib/libc.so.6(+0x3cda0) [0x7fcafe0abda0] ../build_linux/bin/blender(minmax_v3v3_v3+0) [0x7d37b70] ../build_linux/bin/blender(BKE_mesh_minmax+0x42) [0xfb8df2] ../build_linux/bin/blender(BKE_mesh_boundbox_get+0x97) [0xfb8127] ../build_linux/bin/blender() [0x1e2aa08] ../build_linux/bin/blender() [0x1e2afdc] ../build_linux/bin/blender() [0x1e2782e] ../build_linux/bin/blender() [0x1e2ba5d] ../build_linux/bin/blender(snapObjectsTransform+0xab) [0x1e2604b] ../build_linux/bin/blender() [0x1e262fa] ../build_linux/bin/blender(applySnapping+0xa9) [0x1e24fa9] ../build_linux/bin/blender() [0x1e1bcc3] ../build_linux/bin/blender(transformApply+0x71) [0x1de4de1] ../build_linux/bin/blender() [0x1e1e56b] ../build_linux/bin/blender() [0x133f38c] ../build_linux/bin/blender() [0x13407a7] ../build_linux/bin/blender() [0x1340ddc] ../build_linux/bin/blender(wm_event_do_handlers+0x248) [0x1341348] ../build_linux/bin/blender(WM_main+0x20) [0x13372a0] ../build_linux/bin/blender(main+0x336) [0xec0616] /usr/lib/libc.so.6(__libc_start_main+0xd5) [0x7fcafe096b25] ../build_linux/bin/blender(_start+0x2e) [0xf43e0e] # Python backtrace ```
Author
Added subscriber: @georgK
#91717 was marked as duplicate of this issue
Added subscriber: @Wovchick
Member
Member
Member
Added subscribers: @Jeroen-Bakker, @lichtwerk
Member
@Jeroen-Bakker : can you check this?
Apparently caused by 6a88f83d67 @Jeroen-Bakker : can you check this?
Member
Added subscribers: @s12a, @deadpin, @iss
Member
Added subscriber: @ChrisGraz
This issue was referenced by 6cff1d6480
This issue was referenced by 6cff1d648030f65bc299b1abd480c5a36504863d
Added subscriber: @Tilapiatsu
Hi @georgK , @Jeroen-Bakker ,
I have the same issue but with a little twist. The file you have shared workd perfectly for me. But for me the crash is happening only when I try to use the snapping if I have a curve converted from a mesh visible in the scene.
Hiding it is works well, remove the depth works well and deleting it works well
Opening the falty scene on the build from the 10th of september (eab26f1334) works well, but it starts crashing after this build, from 12th of september (b5a1c194c5)
The crash also happening when snapping the 3D cursor
Crash_report_Curve_snap.mp4
CurveSnap_CLEAN.blend
CurveSnap_CORRUPTED.blend
Thanks,
I hope it will help to fix the bug :)
Hi @georgK , @Jeroen-Bakker , I have the same issue but with a little twist. The file you have shared workd perfectly for me. But for me the crash is happening only when I try to use the snapping if I have a curve **converted from a mesh** visible in the scene. Hiding it is works well, remove the depth works well and deleting it works well Opening the falty scene on the build from the 10th of september (eab26f1334) works well, but it starts crashing after this build, from 12th of september (b5a1c194c5) The crash also happening when snapping the 3D cursor [Crash_report_Curve_snap.mp4](https://archive.blender.org/developer/F10687221/Crash_report_Curve_snap.mp4) [CurveSnap_CLEAN.blend](https://archive.blender.org/developer/F10687232/CurveSnap_CLEAN.blend) [CurveSnap_CORRUPTED.blend](https://archive.blender.org/developer/F10687234/CurveSnap_CORRUPTED.blend) Thanks, I hope it will help to fix the bug :)
Added subscriber: @mano-wii
Germano Cavalcante self-assigned this 2021-09-30 17:51:55 +02:00
Although the issue was introduced in 6a88f83d67, this only revealed an error in the snap code and one that is already being handled for example in D12282: Fix #90808: Undo curve selection recalculates boundbox based on curve data.
Fix on the way.
Although the issue was introduced in 6a88f83d67, this only revealed an error in the snap code and one that is already being handled for example in [D12282: Fix #90808: Undo curve selection recalculates boundbox based on curve data](https://archive.blender.org/developer/D12282). Fix on the way.
On further investigation, I'm not sure how 6a88f83d67 might have introduced the problem.
This problem has more to do with b9febb54a4, which forces the conversion of this type of curve to Mesh.
On further investigation, I'm not sure how 6a88f83d67 might have introduced the problem. This problem has more to do with b9febb54a4, which forces the conversion of this type of curve to Mesh.
9 Participants
Reference: blender/blender#91734
