control Panel greyed out in 2.93.4 #91776
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#91776
Graphics card: Intel(R) Iris(R) Plus Graphics Intel 4.5.0 - Build 27.20.100.8681
Broken: version: 2.93.4, branch: master, commit date: 2021-08-31 09:23, hash:
blender/blender@b7205031ce
Addon Information
Name: Sapling Tree Gen (0, 3, 4)
Author: Andrew Hale (TrumanBlending), Aaron Buchler, CansecoGPC
Added subscriber: @Revuelto-2
Added subscriber: @mano-wii
This report does not contain all the requested information, which is required for us to investigate the issue.
Please, be sure to provide system information, last Blender version which worked, and a .blend file with exact steps to reproduce the problem.
A guideline for making a good bug report can be found at https://wiki.blender.org/wiki/Process/Bug_Reports
Just open default scene, delete cube, add a tree and the control panel shows but can not be used. It works in 2.83 but not 2.93.4
system info and screen grab of greyed out tree dialog.
system-info.txt
tree_not working.blend and a scene with default tree. Note dialog closes when saving scene.
I cannot reproduce this with either the latest stable or current development versions of Blender:
Please try the latest daily build: https://builder.blender.org/download/
Go to File → Defaults → Load Factory Settings and then load your file to see if you still can reproduce this issue.
If the problem persists, please give us more clear instructions on how to reproduce it from scratch.
Hi, I think
Global Undo
is not enabled. Try enable it from {nav Edit> Preferences > System > Global Undo}May be that will resolve the issue. If not, please follow the instructions which Germano has mentioned :)
Pratik Thank you very much.
The global undo was unchecked (I do not recall turning it OFF but must have).
Turning it back ON (checked) fixed the Tree generator
Thank you very much. I appreciate the help
Changed status from 'Needs User Info' to: 'Resolved'
Good to know its working. Will close then. Thanks again for the report :)
