Setting a curve to Cyclic causes the Geometry Nodes to evaluate the Normal direction of the curve incorrectly. #91953
Reference: blender/blender#91953
Operating system: macOS-11.6-x86_64-i386-64bit 64 Bits
Graphics card: AMD Radeon Pro 560X OpenGL Engine ATI Technologies Inc. 4.1 ATI-4.6.20
Broken: version: 3.0.0 Alpha, branch: master, commit date: 2021-10-04 07:43, hash:
8c55333a8e
If you turn a curve Cyclic, Geometry Nodes calculates the normal direction of the curve incorrectly. This is easiest to see if you use the Curve to Mesh node to create a mesh, display the normals of the curve in Edit mode, manipulate the curve to give it a unique shape, and then tweak the cyclic value.
Now, select the curve and switch to edit mode.
In the Viewport Overlays, increase the display of the Normals until you can see them for the curve.
Adjust the curve until it's twisted.
Now in the Properties Panel for the curve, under Active Spline toggle on and off Cyclic. Notice that the mesh doesn't line up with the normals when Cyclic is on.
or
cyclicOffset.blend
Added subscriber: @JasonSchleifer
Added subscriber: @OrestisKonstantinidis
Unfortunately, this is a limitation currently. The old code to compute normals did not work entirely correct on cyclic splines. We tried to keep the geometry nodes implementation close to the original implementation while still fixing the bug (didn't even know how to write the algorithm so that it has the same bug..). This is also mentioned in the original patch: D11621. In the long term the fixed implementation should be used all over Blender of course.
Here is an example where the old algorithm failed and geometry nodes does the correct thing on the same curve:
old_normal_calculation_buggy.blend
