Custom Properties Soft Limit reset v 3.0 Alpha #92037
Reference: blender/blender#92037
Graphics card: GeForce RTX 3090/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 456.71
Broken: version: 3.0.0 Alpha, branch: master, commit date: 2021-10-06 22:38, hash:
439c9b0b84
Worked: 2.93.6 (
0930a70e81
)Short description of error
I set a custom property and when I play with the value, the soft limit parametre gets switched on and reset to "0".
If you try Editing the Property again, you will see that the "Use Soft Limit checkbox" has been ticked ON! And Soft Min/Soft Max have been reset to "0"!!!
That's the bug.
I can make it work if I keep the "Use Soft Limits" checkbox ON. The bug is when I want it OFF.
More context about the file :
That property (bugged_prop) is driving a Factor value from a Mix Shader node that is connected to the entry socket of a group node belonging to a Material of the Object named "Child".
[Side note : I also noticed (when simplifying the blend file to report the bug) that if I Edit a custom property by changing it's name, then the value stops beeing a driver (maybe thats normal but I wanted to point it out). It would be great if renaming the prop would also update the drivers path.]
The other two custom properties work just fine although I've unchecked the "Use soft limit checkbox" but they have a "float" type and not "int". And they are driving shape-keys of the same object.
Test File:
Bug (24).blend
Added subscriber: @YvesPerera
Custom Properties Soft Limit resetto Custom Properties Soft Limit reset v 3.0 AlphaAdded subscriber: @PratikPB2123
This issue was referenced by
886196b888
Thanks for the report!
You're most welcome. :)
Thank YOU for fixing it!
