Geometry Nodes: Random Value node connected to Subdivision Mesh level socket gives error, but still appears to function. #92327
8 Participants
Reference: blender/blender#92327
Graphics card: NVIDIA GeForce RTX 3060/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 496.13
Broken: version: 3.0.0 Alpha, branch: master, commit date: 2021-10-16 12:26, hash:
4a00faca1a
Worked: NA
Random Value node connected to Subdivision Mesh gives error, but still appears to function.
random_val_bug.mp4
subdiv_bug.blend
Added subscriber: @valera-8
Added subscriber: @leesonw
Could you add a sample scene to this?
I have added an example file.
Added subscriber: @Walnert
What would you like the fix to be? Since it still works, I think just turning it into a regular line, not a red dotted line, would be a good fix.
Added subscriber: @Eary
Not quite though. It seems it just converts the field into a single constant value, I think the red line still needs to be there to signal the field does not work here
Added subscribers: @JacquesLucke, @HooglyBoogly
The reason the random value node outputs a field in this case is that is has an implicit id/index input (which is also a field). Because the "Level" socket isn't evaluated as a field, that implicit input doesn't work.
Ideally there would be some way for the random value node to not have a field implicit input when it is connected to a single-value (non-field) socket.
@JacquesLucke, do you think that is a reasonable goal?
I think we could change the behavior in
evaluate_constant_field
. If the field has any input, we just return the default value instead of actually evaluating the field.I don't know if there is a point in that since the Random Node will just generate a constant value that user can set from the start without playing with the seed value.
What I need is to somehow have a random seed value that will be randomized just by duplicating the object with the GN modifier, instead of manually changing the group input seed value on each duplicated object if I want to have a slightly different version. This way I can just paint these objects on a surface and have randomly generated geometry right away.
Another solution would be for me to write a script to change the seed values of all the objects I guess..
Thanks sounds good to me.
@valera-8, to be clear, fixing this won't give a random-per-object output, that would have to something else, maybe another node.
I tested this on a few other nodes, and it looks like it gives a red error-line when you connect the field to any single-number input in the next node. Ex. icosphere radius, all grid node inputs.
It seems like the fix would be to have the field understand when the input it's connected to only wants a single number, then downgrade itself from a field output to a single number output just for that node.
This issue was referenced by
cc388651eb
