Geometry Nodes: Set Position node uses implicit position for "Offset" mode, causing unintended displacement #92348
6 Participants
Reference: blender/blender#92348
Operating system: macOS Big Sur 11.2.3
Graphics card: AMD Radeon Pro 5500M 8 GB
Broken: 3.0 Alpha,
4a00faca1a
, master, 2021-10-16Worked: Unkown
Currently the "Set Position" node uses the point position as an implicit input when nothing is connected. This is desirable when not using the "Offset" mode, as it prevents the geometry from all being instantly moved to the origin.
However this implicit position remains even when the "Offset" toggle is enabled, causing each point to be displaced outwards by its own position, effectively scaling the entire object by 2x. The effect is worsened when using selections, as some points default to their own position and others default to a displaced position.
I assume the intended behaviour is to use (0,0,0) instead when "Offset" is enabled, such that no changes to the geometry occur by default, regardless of the mode.
Added subscriber: @RoyTheKoi
Added subscriber: @Eary
I actually liked this behaviour a lot though. Right now checking that check box will visually change the mesh and the user can understand straight up what's going on, Checking that box literally has a visual feedback of the mesh being offsetted. If checking the check box disables the implicit position field, then the user checking that box will not do anything visually, the user might have a harder time understanding what is going on
At the moment, someone who doesn't know about implicit position being used would not know why the mesh scales up arbitrarily, despite nothing connected to the input port. One would think that if no offset vector is passed in, there should simply not be an offset. Offsetting each point by its own position by default is confusing and not very useful.
As far as I can tell, the implicit position input was added to the set position node specifically to prevent unexpected changes to the geometry when there is no explicit input (D12553). Right now there is no change by default when offset is off, I believe the same should be true even when offset is on.
If seeing feedback is the goal, all a user would have to do is to plug something into the position input. Changes to the geometry would then make intuitive sense.
I believe that is more because almost nobody wants to collapse your model on the one point, so they just trying to prevent the node from doing so by default.
If checking the offset checkbox doesn't really change how the mesh look, a new user doesn't know anything about implicit position field would just be confused about why this checkbox does not work at all, In many of them might just give up trying to figure out and just went on to the next node.
It also makes more sense to keep the current behavior that way from a tutorial maker perspective. Explaining why this node is based on position by default is so much easier to explain why this checkbox does not change when you keep turn it on and off.
Added subscriber: @erik85
Why would anything change though? The user can see that nothing is connected to the "position"-input and therefore nothing should change regardless of the offset setting in my opinion.
If that's the point then probably it should just not use implicit position field at all, So default would be collapsed into one point, checking that offset checkbox would turn the model back to normal.
In my opinion, either that or keep the current behavior
I think having the geometry scale up by 2x is just as unwanted as collapsing everything to a point. If someone wanted that they could use a transform node instead.
I imagine a new user might try to plug something into the position input before giving up on the node altogether. It makes more sense for the node not to change the geometry until an explicit input is given.
Also, if a new user is confused, they can easily check the documentation where the node should be clearly explained.
Tutorial makers can explain that the node does nothing until an input is connected. This is a simple explanation and makes the most intuitive sense to me.
Okay I see your point here, I think I am fine with this then
I'd be fine with changing the behavior, but it's a bit tricky implementation wise. We could make it work by turning the Offset input socket into an enum on the node and having separate Position and Offset sockets.
Hans had an idea for a good alternative. We could just have separate Position and Offset vector sockets that are always there. Will create a patch for that.
Separate position and offset sockets sounds like a good solution. My only question is would the position and offset vectors both be evaluated before moving the geometry, or would they each be evaluated and applied one after the other?
They will be evaluated at the same time, so before moving the geometry.
Ok great. Thanks Jacques!
This issue was referenced by
b3ca926aa8
