Remesh-bug.crash #92355
7 Participants
Reference: blender/blender#92355
Operating system: Linux-4.15.0-159-generic-x86_64-with-glibc2.27 64 Bits
Graphics card: Mesa DRI Intel(R) HD Graphics 5500 (BDW GT2) Intel Open Source Technology Center 4.6 (Core Profile) Mesa 20.0.8
Broken: version: 3.0.0 Alpha, branch: master, commit date: 2021-10-18 21:38, hash:
d7b231baa8
Hi when I try to use the remesh command on this object, Blender crashes
crash-report
{F11295360}
{F11295382}
Added subscriber: @pafurijaz-4
#92484 was marked as duplicate of this issue
#92391 was marked as duplicate of this issue
Added subscribers: @ZedDB, @Sergey, @neXyon, @lichtwerk
Apparently we are confronted with a NULL Audio device (this might be because remesh is fiddeling with a scene in a background job [I recall something with remesh and the scene being the job owner and not the mesh object] -- but I have not checked further), so security check in
sound_verify_evaluated_id
is not enough it seems.CC @ZedDB
CC @neXyon
CC @Sergey
But this also might not be the "real" problem, when doing something like the following (to avoid the crash in Audio)
P2517: T92355_snippet
we are then getting here (which also does not sound pleasing): https://developer.blender.org/diffusion/B/browse/master/extern/quadriflow/src/subdivide.cpp$503
Such tools are expected to localize data in the job's init function (which is run on the main thread) and do not fiddle around with data which is accessed by the main thread. If the remesh is indeed fiddeling with non-localized data it is to be addressed at a much higher priority than adding nullptr checks.
Sorry, this might have come across wrong, not sure quadriflow is actually
altering
anything scene related in the job (it was just my foggy memory of the job being owned by the scene [and not by to object -- but I also recall this had its reasons: progressbar etc]Looks like a depsgraph/memory related bug where I cannot do much!?
The model has several zero length edges which quadriflow can't handle.
(Use "merge by distance" to remove these and it will not crash anymore)
I will have to update the mesh manifold check to check for these.
The reason why we get the backtrace to the sound system is because of race condition were instead of crashing, quadriflow calls
exit()
and blender frees all scene data while an other thread tries to access it.Hi the original model is this but with no boolean modifiers applied.
retopology-experiments.blend
On Blender 2.83LST it works fine, the problem is in 293.lts and in Blender version 3.0 Below the attached file with two objects to do the tests and it works as seen from the video screen.
remesh-B2.83lts.blend
The latest file you attached works in master as well (because it doesn't have zero length edges).
I'm unsure what you are trying to say.
In the first I applied the modifiers with Blender 3.0 and in the second I imported the scene in Blender 2.83, and I applied the modifiers and I ran the command remesh, this means that in Blender 3.0 and in Blender 2.93 when you apply the modifiers both generate a corrupted mesh is .
You can try because I attached the original file from which I imported the scene from 3.0 to test with Blender 2.83LST, I don't know what the problem is but it is not that one has to remodel or redo the objects it is evident that there is a problem.
Did you try the latest 3.0 version?
For me applying the modifiers doesn't not create zero length edges in master.
This issue was referenced by
77104bf318
10fb5cc58d
In either case, the issue with generating invalid meshes is an other issue. So the reported crash has been "fixed", so I'll close this.
But what do you say this is a crash problem which originated from a file where I applied the modifiers and then tried to use the remesh command, it's not another problem it's a problem with Blender 3.0
I've tested now and it's crash this is the file made with Blender 3.0 the other for 2.83lts has a different boolean object when the one for the 3.0 has an object made by boolean union
The original model is this but with no modifiers applied.
I'm saying that the invalid geometry generated by the boolean modifier is an other issue.
You reported that blender crashed when quadriflow was used on bad meshes with zero length edges.
I've added a check so the operator does not run on meshes with zero edge length edges now.
So the issue for this ticket is fixed and now closed.
Ok so now I've to create an other report for this issue?
If someone else hasn't already reported this issue, then you should report it as an other issue, yes.
Added subscriber: @mano-wii
Added subscriber: @iss
