Node Wrangler (3, 38) can't work #92686
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#92686
Graphics card: GeForce GTX 1050 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 456.55
Broken: version: 2.93.5, branch: master, commit date: 2021-10-05 12:04, hash:
blender/blender@a791bdabd0
Addon Information
Name: Node Wrangler (3, 38)
Author: Bartek Skorupa, Greg Zaal, Sebastian Koenig, Christian Brinkmann, Florian Meyer
Python: Traceback (most recent call last):
ValueError: path is on mount 'H:', start on mount 'G:'
Node Wrangler (3, 38)can'tWork.blend
Added subscriber: @Qing_Yi_Meng_Zhi_Cheng
Hi, thanks for the report. Please provide steps for reproducing the issue.
(A guideline for making a good bug report can be found at https://wiki.blender.org/wiki/Process/Bug_Reports)
thank you to reply my answer
For details, you can refer to the blender fileI uploaded.
There is a more detailed problem report.(in the blender document)
I added a notepad in it, you can take a look,
I also write some information in the node window
Simply put, when using ctrl shift T at what point is an error reported
IF i put the picture in the G: that the addons can work
The result I want has been placed in the blender file
Added subscriber: @smramsay
Pretty sure this is fixed in the latest release by D12221
If you can't update, then you need to uncheck 'Relative Path' in the right side panel.
Files can't have relative paths across Windows drives.
Hi @Qing_Yi_Meng_Zhi_Cheng , could you please try again with fresh builds?: https://builder.blender.org/download/daily/
