geo nodes breaks auto smooth and weighted normal modifier. #92948
Open
opened 2021-11-09 04:09:01 +01:00 by michael campbell · 12 comments
Operating system: Windows-10-10.0.19042-SP0 64 Bits
Graphics card: NVIDIA GeForce GTX 1070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 472.12
Broken: version: 3.1.0 Alpha, branch: master, commit date: 2021-11-07 23:45, hash: 4f387e66ac
Open file, turn on rendered view (cycles). Left cube is created with geo nodes, right is a standard cube. Both have same material, and both have auto smooth enabled. Only the standard cube works. Weighted normal modifier is also broke.
normals break after geo node.blend
**System Information** Operating system: Windows-10-10.0.19042-SP0 64 Bits Graphics card: NVIDIA GeForce GTX 1070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 472.12 **Blender Version** Broken: version: 3.1.0 Alpha, branch: master, commit date: 2021-11-07 23:45, hash: `4f387e66ac` Worked: (newest version of Blender that worked as expected) Open file, turn on rendered view (cycles). Left cube is created with geo nodes, right is a standard cube. Both have same material, and both have auto smooth enabled. Only the standard cube works. Weighted normal modifier is also broke. [normals break after geo node.blend](https://archive.blender.org/developer/F11771923/normals_break_after_geo_node.blend)
Added subscriber: @3di
Contributor
Added subscriber: @Eary
Contributor
I don't think it's a bug, there is a patch for this but it doesn't seem to get anywhere D12080 Hope there will be some solution soon.
I don't think it's a bug, there is a patch for this but it doesn't seem to get anywhere [D12080](https://archive.blender.org/developer/D12080) Hope there will be some solution soon.
Member
Member
Member
The auto-smooth option is currently not working with geometry nodes indeed. We still haven't fully decided what do with it. Personally, I'm not a fan of using a tag on a mesh to indicate the render engine that it should somehow smooth the normals. There should be better solutions such as edge split and custom normals (which auto-smooth seems to be using internally anyway).
Added subscriber: @HaniTiby
Smoothing in blender was really confusing to me although I was Max user, it's so strange that the "Object > Shade Smooth" command is not enabling the normals Auto Smooth checkBox automatically
Or the opposite direction, if a user checks normals Auto Smooth, it should automatically set Shade Smooth.
Any way, Auto Smooth must work somehow
> In #92948#1250996, @JacquesLucke wrote: > The auto-smooth option is currently not working with geometry nodes indeed. We still haven't fully decided what do with it. Personally, I'm not a fan of using a tag on a mesh to indicate the render engine that it should somehow smooth the normals. There should be better solutions such as edge split and custom normals (which auto-smooth seems to be using internally anyway). Smoothing in blender was really confusing to me although I was Max user, it's so strange that the "Object > Shade Smooth" command is not enabling the normals Auto Smooth checkBox automatically Or the opposite direction, if a user checks normals Auto Smooth, it should automatically set Shade Smooth. Any way, Auto Smooth must work somehow
Member
Added subscriber: @RoyTheKoi
There is a workaround for this. You just need to join the original geometry (from the group input node) with the procedural geometry using a join geometry node. Make sure the original geometry is the top-most input on the join geometry node otherwise this will not work.
This workaround also helps with getting vertex groups on procedural geometry, which can be used in other modifiers.
There is a workaround for this. You just need to join the original geometry (from the group input node) with the procedural geometry using a join geometry node. Make sure the original geometry is the top-most input on the join geometry node otherwise this will not work. This workaround also helps with getting vertex groups on procedural geometry, which can be used in other modifiers.
Member
Ref #93208.
Ref #93208.
Philipp Oeser removed the
label 2023-02-10 08:44:29 +01:00
6 Participants
Reference: blender/blender#92948
