Undo after changing Origin pivot will move entire Geometry #93122
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#93122
Blender 2.93.1
Short Description
In Edit Mode, use one of the Origin operations (Origin to Selected, to 3D Cursor, to Geometry, ...), then doing an Undo, will move the entire object's geometry to the Origin's new location, but with the relative location of the old Origin
Steps to Reproduce
3D Viewport Pie Menus
addonOrigin to Bottom
(select any)Workaround:
Undo has to be used again in Object mode to work
Added subscriber: @xeoncat
Added subscriber: @lichtwerk
How do you even execute this in Editmode? (this should not be allowed, giving you the
Operation cannot be performed in editmode
error)I'm absolutely sure you can, both from the pie menu (Ctrl+Alt+X) and by searching the name of the operation, (and if it wasn't intended to be, it's easily one of the most useful operations)
Hi, Origin Menu is available with
add-on.And I can reproduce this on master. Will mark this as confirmed :)
Ah, OK, wasnt aware the Addon would do this
Internally, all it does is this though:
but wrapping this in a single undo step somehow confuses blender (I think this happens elsewhere as well if modeswitches are involved).
You would probably get around it by unchecking
Global Undo
in Preferences (but this is a worse workaround than is already suggested).
