Crash when playing metaball particle animation in rendered view (cycles) #93199
6 Participants
Reference: blender/blender#93199
Ok, I simplified this a lot: simply adding a particle system emitting metaballs with object scale set to 1 to the default cube will trigger the crash or UI freeze.
Open attached Cycles anim crash 5.blend file from below comments and enable rendered view in cycles. Press space to start the animation playing.
--- old info: ---
Operating system: macOS-12.0.1-arm64-arm-64bit 64 Bits
Graphics card: Apple M1 Max Apple 4.1 Metal - 76.1
Broken: version: 3.0.0, 3.5, 4.0, 4.1.0 Alpha, branch: main, commit date: 2023-11-24 22:55, hash:
42ddc13033c2
Worked: unknown
Playing animations in cycles rendered view frequently crash blender. With the attached file I consistently get a crash within 1-2 minutes of starting the animation.
The crashes do not occur when running the intel version through rosetta. They occur much faster/more often when using the CPU than when using the GPU.
Open attached file
Switch to rendered view (Crashes with and without Metal preference)
Press spacebar to play
Boat boating.blend
Animation crash.txt
Added subscriber: @blenderrocket
Sometimes while playing it also gets stuck at Updating Geometry BVH Mball and most of the UI gets unresponsive.
In general, playing animations in cycles rendered view has a very high tendency to crash, they seems to occur much more often than on my previous intel Mac..
Added subscribers: @mano-wii, @iss
@mano-wii Can you check?
Still happens with 3.0 final release.
I cannot reproduce this with either the latest stable or current development versions of Blender: https://builder.blender.org/download/
Go to File → Defaults → Load Factory Settings and then load your file to see if you still can reproduce this issue.
If the problem persists, please give us more clear instructions on how to reproduce it from scratch.
Operating system:
macOS-11.6-arm64-arm-64bit 64 Bits
Graphics card:
Apple M1 Apple 4.1 Metal - 71.7.1
Blender Version:
3.0.0, branch: master, commit date: 2021-12-02 18:35, hash: f1cca30557
Hi, thanks for testing. With factory defaults I can still easily reproduce this in 3.0 final release and in the latest 3.1 daily build (version: 3.1.0 Alpha, branch: master, commit date: 2021-12-07 16:47, hash:
a37dac0a88
). The crashes basically happen while doing anything in cycles rendered view, but occur most often and consistently when playing animations in the viewport. Sometimes within seconds of pressing play, sometimes after up to a few minutes; when just editing I will run into a crash within 15-30 minutes usually. It is about 50/50 whether blender fully crashes or only the ui locks up without a crash.The crashes are specific to the apple silicon build, when I use the intel version on the same m1 MacBook Pro, the crashes do not occur. Unfortunately I can't give more specific steps than above to reproduce, I can add more crash reports if that is helpful.
Sometimes I also get this effect where the rendered view stops updating, a few clicks after that the ui will completely lock up:
Schermopname 2021-12-07 om 20.40.19.mov
Same with metal GPU enabled, frequent crashes in rendered viewport. One report with metal enabled just in case the problem might be different:
Crash metal.txt
Added subscriber: @Leonard-Gottert
I can reproduce the crash as well as viewport shading not updating using the boat boating blend file. For me, Blender crashes after 10 to 60s when using CPU rendering. I just go into viewport shading and start the animation, then leave Blender alone.
I could not reproduce with GPU rendering (within a reasonable amount of time).
Operating system: macOS-12.1-arm64-arm-64bit 64 Bits
Graphics card: Apple M1 Pro Apple 4.1 Metal - 76.3
Broken: version: 3.1.0 Alpha, branch: master, commit date: 2022-01-07 23:28, hash:
741ed5fcd2
Added subscriber: @michael64
@michael64 can you see if this is the same as #94736? I get a lot of crashes in rendered view with the M1 build (but not in the intel one); it is hard to see if it is all the same bug(s) or if I need to file multiple reports.
@blenderrocket, this crash is very different from #94736.
As one can see in F11826548 thread 16 calls ccl::BVHEmbree::build which calls embree::sse2::BVHBuilderMorton::BuildPrim via tbb which crashes in thread 17.
The Cycles Metal implementation is not involved here at all.
I suspect this is the case even for the F12737533 but there macOS could not even create a proper crash report so I can't say for sure.
I tried to reproduce the crash on Apple M1 and got three crashes so far but always by doing random UI interactions and I found no way of forcing a crash or even make it more likely.
So multiple bugreports are definitely called for here.
Also if you like you could upgrade to macOS 12.1. This will not make the crash go away but it might help in generating a proper crash report when using Metal.
The comments seem to mix up different issues.
Considering only the original .blend file from the report, is this issue still seen with the latest daily build and macOS 12.2?
Still can't replicate.
Operating system:
macOS-12.2-arm64-arm-64bit 64 Bits
Graphics card:
Apple M1 Apple 4.1 Metal - 76.3
Yes, both crashes and the UI freezing still occur with the latest 3.1 build
I get these crashes a lot (like every few minutes) whenever doing anything in cycles rendered view, not only with this file.
Crash log reproduced with the same .blend:
CrashLatest.txt
Operating system: macOS-12.2-arm64-arm-64bit 64 Bits
Graphics card: Apple M1 Max Apple 4.1 Metal - 76.3
Broken: version: 3.1.0 Beta, branch: master, commit date: 2022-02-09 17:06, hash:
d1202bd641
It's strange, apparently it seems to be the exact same setup I used, but I can't replicate the problem.
Latest 3.2 dailies are also affected. One thing I noticed just now (as Leonard reported above) is that the crashes occur much faster/often when using the CPU than when using the GPU.
Still affects the latest 3.5 alphas
Operating system: macOS-13.0.1-arm64-arm-64bit 64 Bits
Graphics card: Apple M1 Max Apple 4.1 Metal - 83
Broken: version: 3.5.0 Alpha, branch: master, commit date: 2022-12-15 23:50, hash:
e58f5422c3
@blenderrocket hi, does it crash if you run blender with
-t 1
argument?It doesn't seem to crash then, I have been playing the animation for about 30 minutes without any crash.
Changed status from 'Needs User Info' to: 'Needs Developer To Reproduce'
Added subscribers: @Michael-Jones, @brecht
Thanks. Looks like a threading issue then.
@brecht, @Michael-Jones , can you check?
Open attached file and enable rendered view. Press space to start the animation playing.
And the corresponding crash log.
Crash when playing animation in rendered view (cycles)to Crash when playing metaball particle animation in rendered view (cycles)
