Nodewrangler report an error when pressing CTRL+T to import multiple texture #93215
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#93215
Operating system: Windows 10 Pro
Graphics card: NVIDIA RTX 2080Ti
Broken: (example: 2.80, edbf15d3c044, master, 2018-11-28, as found on the splash screen)
2.93.5 & 2.93.6 Official release
When I want to import multiple texture in shader editor via Node Wrangler pressing CTRL+T, nothing happens and an error occur.
In the Shader Editor I have created a material node. Select Principled BSDF and press CTRL+T , then selected the image files (named correctly with xy_COL.jpg, xy_NRM.jpg etc.). A warning dialog box appear saying: Relative paths cannot be used with unsaved scenes.
Saved the file and tried again the same procedure. When I select all the images I want, nothing will be imported and the error (screenshot attached to this bug report) appears. It was working with 2.93.4. Now it does not work with 2.93.5 as well as 2.93.6 official release.
Same procedure works with 3.0.0 Beta downloaded November 18.
Added subscriber: @LenioCrameri
Added subscriber: @EAW
On what drives are the:
D, C, and F are mentioned in the error.
All Blender are installed as Portable in D:. Config Files in AppData
Image Files are located in F:
Added subscribers: @lichtwerk, @PratikPB2123
Issue is same as described in #77022.
Fix for this is not included in
blender-v2.93-release
. @lichtwerk , can you please check?Hi, I can confirm that disabling the Relative Path option in the file browser is fixing the error. Nevertheless, I hope the issue will be fixed in 2.93.6.
Many thanks guy's.
I put this on the list to be backported to 2.93 LTS, see blender/blender#88449 (Blender LTS: Maintenance Task 2.93).
No need to have a separate report open for this though, this will be included in the next LTS release.
