Struct of Arrays Refactor for Mesh Vertices #93602
7 Participants
Reference: blender/blender#93602
Currently,
MVert
stores quite a bit of data:This is inefficient, because it means vertex positions aren't stored in a contiguous array.
It also means all of the other data isn't stored contiguously. Because of that, access to all of the data
is slower than it should be. We also pay the cost of storing data when it's unused.
We should convert
MVert
to be the same asfloat3
, and move the other elements into separate arrays.This can significantly simplify code, and makes it easier to achieve better performance for mesh editing.
Normals
Normals are covered by #91186 (Move mesh vertex normals out of MVert). This task is for the rest of the data stored in the struct.
Bevel Weight
In the longer term, this should be stored as an optional named generic float attribute (see #89054).
In the shorter term, this can be stored as
CD_BWEIGHT
. This means slightly increased memory usage when this data is used,but it also gives increased precision, and it doesn't have to be allocated when it isn't used.
291c313f80
Flag
In the flag is:
Selection
It's not clear to me how selection interacts with
mselect
(MSelect
), but perhaps it can be moved there.It can also be moved to a separate boolean custom data layer with a name that keeps it from being displayed in the UI.
TMP_TAG
90a23dec46
Since this is only used locally in one area, it can be easily replaced with
Array<bool>
or the C equivalent.ME_HIDE
2480b55f21
This can be moved to a separate boolean custom data layer, likely with a reserved name.
Face Dot
8c25889bb6
Currently this is only set by subdivision code. I'm not clear on the details.
Face dot vertices could be moved to a separate array, since they are just runtime data.
PBVH Update Tag
7682d7de04
This is just used in sculpt and paint code, it could be relatively simply moved to a bitmask or a separate boolean array.
Internal Mesh API
When there is a
position
attribute, functions that refer to mesh "coords" and "vertices" should be changed to refer to "positions" instead.This makes the internal API consistent with more public naming of attributes. This should affect the functions added in D14760.
Added subscriber: @GeorgiaPacific
This issue was referenced by
cfa53e0fbe
Added subscriber: @Zeastin
Added subscriber: @Garek
Added subscriber: @Baardaap
90a23dec46
Convert Mesh vertex data into float3to Performance: Convert Mesh vertex data into float3This issue was referenced by
7682d7de04
22c60ac8b1
Performance: Convert Mesh vertex data into float3to Convert Mesh vertex data into float3Convert Mesh vertex data into float3to Struct of Arrays Refactor for Mesh VerticesThis issue was referenced by
8c25889bb6
2480b55f21
291c313f80
12becbf0df
Added subscriber: @EAW
1af62cb3bf
sixthat referenced this issue2023-03-14 11:12:01 +01:00
