Spreadsheet doesn't refresh after instance collection's names are changed in 3.0 stable. #93683
Reference: blender/blender#93683
Operating system: Windows 10 20H2
Graphics card: RTX 3090
Broken: 3.0 stable
As the topic, changing sub collection's name doesn't affect the collection info node.
Set up a geometry node and use collection info node to load a collection which contains sub collection.
Change sub collection's name (rename
Collection 3
in outliner)Names in spreadsheet remain unchanged.
#93683.blend
Added subscriber: @NXSK
Spreadsheet doesn't refresh after instance' names are changed in 3.0 stable.to Spreadsheet doesn't refresh after instance collection's names are changed in 3.0 stable.Added subscriber: @PratikPB2123
Added subscriber: @BEHE
so it seems that the issue is not only for collections but also object names
it only upsates if you deselect the object which has geometry node mosifier and select it again
i can confirm the issue in 3.3
since i'm not that talented
i will just give what i found out until now so the fatest way to jupdate the collection name is to hide it in render while it's enabled and then disable it it will update of course you can enable it again
BTW the order cannot be reversed you hgave to play with hiding the render then disabling the collection
well i found an even easier solution which is just enabling or disabling either the show in viewport or render option so you have the coice in the object which has the geometry node modifier
propably enabling and disabling it reload things
Instances names now updates when hovered over the spreadsheet (this wasn't the case in until 3.2)
I guess this was improved in
72f77598a2
I guess we can close this as resolved then?
Issue is still there but priority can be lowered. I think spreadsheet should update on rename.
in 3.3 and newer versions, Spreadsheet doesn't refresh after renaming the collection (need to hover the mouse on spreadsheet)
while in previous versions names weren't updating even after hovering the mouse.
@HooglyBoogly I think we can close this report. The original issue has been fixed already.
Remaining problem is actually a known issue as mentioned in
5f59bf0044
Thanks Pratik!
