Unable to import PDB file using PDB/XYZ addon #94008
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#94008
Operating system: Linux-5.4.0-91-generic-x86_64-with-glibc2.31 #102-Ubuntu SMP Fri Nov 5 16:31:28 UTC 2021 x86_64 x86_64 x86_64 GNU/Linux
Graphics card:
Broken: io_mesh_atomic addon in blender 3.0.0, branch: master, commit date: 2021-12-02 18:35, hash: f1cca3055776, type: release
Python version: 3.9.7 (default, Oct 11 2021, 10:06:01) [GCC 9.3.1 20200408 (Red Hat 9.3.1-2)]
Importing a PDB file failes because of the use of a not assigned variable in the python script.
When trying to import a PDB file generated by OpenBabel, the following error arises:
{F12736494, size=full}
The source code uses the variable
line
that is actually a local loop variable in the previous block as you can see:{F12736503, size=full}
Added subscriber: @dadel
Hi, thanks for the report. Seems broken from the very first revision.
Can confirm. (Will check if I can fix this)
I import the exported file from blender and still it appeared (Which is expected because line is used away from the for loop scope)
Added subscriber: @Blendphys
Changing the scope does not fix importing issue here (may be I am doing some mistake).
Hi @Blendphys, can you look at this?
Hi all.
It seems that there is an issue with the file pointer 'filepath_pdb_p' since 'line' has no value from the beginning of the loop.
Hmm, I have Blender version 3.0 on a different computer and will deal with this on Monday. I keep you informed. Please, be patient ... ;-)
PS: Please, can you send the PDB file which you were using? Thanks.
Dear Dadel and Patrik.
I tested a dozen of PDB and some XYZ files: there is no problem, I can import all structures.
To proceed, I would like to have your PDB files, Dadel and Pratik. With this, I can then check what is going on. Below, you find some specifications of the system, which I'm using.
Blender 3.1.0 Alpha System Information
Blender:
version: 3.1.0 Alpha, branch: master, commit date: 2022-01-03 13:46, hash: a3e634d4d7a3, type: Release
build date: 2022-01-03, 14:30:42
platform: 'Linux-5.4.0-91-generic-x86_64-with-glibc2.27'
Python:
file system encoding: utf-8:surrogateescape
Python (External Binary):
binary path: '/home/cle/blender-git/build_linux/bin/3.1/python/bin/python3.9'
version: Python 3.9.7
GPU:
renderer: 'Quadro RTX 4000/PCIe/SSE2'
vendor: 'NVIDIA Corporation'
version: '4.5.0 NVIDIA 460.91.03'
Cycles:
CPU device capabilities: SSE2 SSE3 SSE41 AVX AVX2
CUDA device capabilities:
Quadro RTX 4000
Changed status from 'Confirmed' to: 'Needs User Info'
Bit strange. I was getting traceback earlier. (with same error message:
local variable line referenced before assignment
)Now I am seeing different error (I will submit a separate report for it)
Hi @dadel , can you please provide a broken .pdb file?
Patrik, I do not wonder that things do not work considering the other report (https://developer.blender.org/T94292): the user should be in the 'Object' and not in the 'Edit' mode!
Let's hope that we get the PDB file ... .
Added subscriber: @scurest
I'm pretty sure this can only happen for an empty .pdb file. Otherwise the
for line in filepath_pdb_p
loop would have been entered, so line would be assigned.Small note: I just changed the code such that the user is now always in the 'OBJECT' mode.
See changes: link
PS: Shall we close the thread @PratikPB2123 and @dadel ?
@Blendphys , yes. Will close as we do not have sufficient information (test file).
@scurest , on importing empty pdb file I get ZeroDivisionError (not the same as said in this report).
@dadel feel free to comment or reopen the ticket if issue persists with recent fixes. Be sure to provide sample file to test the issue. Thanks for the report!
