Render crayon layer #94430
Reference: blender/blender#94430
Graphics card: GeForce GTX 1050 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 456.71
Broken: version: 3.0.0, branch: master, commit date: 2021-12-02 18:35, hash:
f1cca30557
When you render an image, the crayon layer is forced to appear in front, causing other objects to be blocked.
Object mode: the crayon is behind the cube,
Rendering result: the crayon is in front of the cube
Added subscriber: @zainiuxiaodao
Added subscriber: @lichtwerk
Could you provide your example .blend file, please?
Z pass is disabled by default. Please check if enabling Z pass resolves your issue: {nav View layer properties > Passes > Data > Z pass}
You can also see warning message appeared on Rendering window:
Warning: To Render grease pencil, enable Combined and Z passes
Otherwise, share a .blend file as requested by Philipp :)
