Keying preference 'Only Insert Needed' functionality has changed unexpectedly #94719
2 Participants
Reference: blender/blender#94719
Operating system: Linux-5.8.0-7630-generic-x86_64-with-glibc2.32 64 Bits
Graphics card: AMD Radeon RX 5700 XT (NAVI10, DRM 3.38.0, 5.8.0-7630-generic, LLVM 11.0.0) AMD 4.6 (Core Profile) Mesa 20.3.2
Broken: version: 3.0.0, branch: master, commit date: 2021-12-02 18:35, hash:
f1cca30557
The behavior of 'only insert needed' option in the animation preferences has changed unexpectedly. The functionality is non-existent when the option is enabled together with 'Only Insert Available' option.
When 'Only Insert Available' is disabled, the 'Only Insert Needed' is behaving as expected, unless the user wants to add keyframes manually (hitting 'I' shortcut) according to the active 'keying set'. When the user has added a keyframe manually by hitting 'I', All channels (active keying set) are keyed, except for the channel(s) that were previously keyed by 'Only Insert Needed'.
Previously, the 'Only Insert Needed' option, gave an error when the user would try to manually put in a keyframe ('I').
Open the example file (attached)
Go to preferences -> Animation -> Keyframes:
Turn on 'Only Insert Needed'
Turn off 'Only Insert Available'
Set Keying Set to 'LocRotScale + properties'
In the viewport make sure you have 'Item' visible in the N-panel to check the keying behavior
Delete existing keys on the cube (in Dopesheet) (Or create a new action)
Set a key on frame 0 by hitting 'I' to key all channels
Set the timeline on frame 10 and only rotate the cube in any direction. This should only put keys on the rotation channels
Go to frame 5 and hit 'I' to set keyframes on all channels. This will result in keys on inverted channels. Iin this example, because we changed the rotation on frame 10, rotation is not keyed by the user. This is strange behavior.
keying_only_insert_needed_issue.blend
Added subscriber: @Rikstopher
Added subscriber: @dr.sybren
The described behaviour was already present in old versions of Blender (tested down to 2.83, but looking at the source code it could have been introduced in 2.5x already). So even if you may have found something that changed recently, what is described in this task did not.
