Solidify modifier showing opposite output than usual. #95149
5 Participants
Reference: blender/blender#95149
Operating system: Windows-10-10.0.19042-SP0 64 Bits
Graphics card: Intel(R) Iris(R) Plus Graphics Intel 4.5.0 - Build 27.20.100.9079
Broken: version: 3.0.0, branch: master, commit date: 2021-12-02 18:35, hash:
f1cca30557
I was following Blender Guru's Donut Tutorial. but when i try to apply solidify modifier on the icing, it shows me the inverted result. it shows the icing way thicker when the offset value is -1.000. I've applied the scale value before adding solidify modifier but the problem doesnt solve. Not that it happens everytime. It shows correct output sometimes. I'm attaching the .blend file so that u can see what's wrong.
solidify bug.blend
After that it shows wrong output.
Is there anything i did wrong? or its a bug? please let me know.
Thanks,
Aminul.
Added subscriber: @aminul2111
Added subscriber: @Alaska
The issue is most likely caused by the normals of the faces which the solidify modifier is applying too facing the wrong way.
Looking at the file you provided, everything seems to be correct for the model you have. It's not the "desired" result due to the normals being incorrect for the result you want, but I do not see a bug here.
Can you confirm the donut looks like this to you (This image was taken from below the donut)? Because if it does look like that, then this is the expected result with the model you have and their is no bug here.
Added subscriber: @Gilberto.R
It's not a bug. The solidify is working correctly, in the right direction, but the shape is a bit different depending on the order of the modifiers. You can change the order of the modifiers to get the result you want, if I understood correctly.
OK, looking at the provided file, it's what @Alaska said. The normal of the faces are inverted, probably because of applying negative scale. You just have to flip the faces normals.
Added subscriber: @orleana.v
Hey, @aminul2111
did you manage to find a solution for this? I'm facing exactly the same issue with the same model
The issue is most likely caused by incorrect normals for the result you want. For advice on how to use Blender, please follow tutorials or ask for advice on Blender support sites. https://www.blender.org/community/
If you believe you have found a bug, please file a bug report by selecting from the top of Blender {nav Help -> Report a Bug} and filling out all the relevant information.
