Regression: Broken vertex weight with mirror modifier #95541
6 Participants
Reference: blender/blender#95541
Operating system: Arch Linux 5.15.18-1-lts
Graphics card: AMD ATI Radeon RX 570
Broken: 3.0.1
Worked: 2.9.*
Behavior changed in
1a7757b0bc
...... but that commit got reverted in
e6cd4761e7
The change in behavior is still present in master though (as is the code -- got reintroduced with
a0acb9bd0c
)Short description of error
When mirror modifier is on, the vertex at the mirror plane is only affected by the side that is not mirrored. The mirrored side does not affect vertexes at the mirror plane.
Only happens with new created armatures and new weights, files in older blender projects performs as expected (I'm not sure if it's because I missed some features update, but happens with default configuration).
More details can be found here.
A minimal blend file is attached, which followed:
untitled.blend
Added subscriber: @lygamac
Seems broken in 3.0.0 too, I cannot check where 2.9.* works exactly due to Arch Linux dependencies system (got error with
libtbb.so.2
)Added subscriber: @OmarEmaraDev
Thanks for the report, but the issue reported here is a request for modified/improved behavior and not a bug in current behavior. Closing as this bug tracker is only for bugs and errors.
For user requests and feedback, please use other channels: https://wiki.blender.org/wiki/Communication/Contact#User_Feedback_and_Requests
For more information on why this isn't considered a bug, visit: https://wiki.blender.org/wiki/Reference/Not_a_bug
This is caused by merging the vertices at the center. Blender averages the weights of vertices that got merged, so their weights will be different. I guess this behavior can be changed, but this is not a bug.
It seems the difference is not due to the modifier, rather, it seems the behavior of the automatic weight operator changed between versions. To get the same behavior in 3.0+, you need to enable the X Mirror option when computing the automatic weights. Not sure if this should be considered a bug.
Changed status from 'Archived' to: 'Needs Triage'
Added subscriber: @lichtwerk
With the
X Mirror
option enabled, I get exactly the same results as in 2.93 (where the option also existed) and that is : no influence on the mirror planeWill check which commit changed behavior here.
Thanks for the responce, but for
I'm afraid the problem is not with automatic weights, as I tried to paint the weights myself, and the result was the same: No influence on the mirror plane when mirrored
For the same example file, but manually painted weights on the original side:
Added subscribers: @mont29, @ideasman42
This changed in
1a7757b0bc
e6cd4761e7
The change in behavior is still present though (as is the code -- bisecting between spits out aa1c44a113?), not sure what is going on with git.
CC @mont29
CC @ideasman42
could you check?
We are now mostly considering why there is a difference between older versions and newer versions. In this example, does it work differently on older versions?
Yes, the mirror modifer behaves differently
Raising priority since it is a recent regression, feel free to lower again if this feel unappropriate.
Broken vertex weight with mirror modifierto Regression: Broken vertex weight with mirror modifierAdded subscriber: @HDMaster84
Since the revert #91444 is now an open bug again.
1a7757b0bc
was reverted bye6cd4761e7
, and then re-introduced bya0acb9bd0c
but for new modifiers only. This is why older existing files behave as expected, while newly created ones have the issue.@HDMaster84 so no, #91444 is not open bug again, it's just a bug that cannot be fixed automatically for existing files, users need to manually do it if they want to
Quick follow up, am on it, way the vgroups are merged at the center needs to be changed in new case....
This issue was referenced by
20f819d708
