UI: Label design pattern causes confusion #95604
5 Participants
Reference: blender/blender#95604
In the alembic export settings, for example, an option appears to be labeled with the text in reverse order compared to its name in the tooltips.
This pattern is meant to reduce clutter by not repeating identical parts of adjacent labels and relying on the user to infer the meaning. Perhaps there is a better way to communicate this without repeating the text.
See the example below:
"Transform Samples" appears to be called "Samples Transform".
"Geometry Samples" appears to be called "Geometry"
However, the UI is meant to be interpreted as follows...
The same pattern is used for Frame start/end (also displayed in the image above.) In this case, the intent is more clear in part due to the connected button sliders, and also, start frame and end frame are familiar concepts that any user would expect to find next to each other.
Transform samples and geometry samples are more abstract concepts by comparison.
To reproduce
Added subscriber: @tiles
Thanks for the report. Can be improved to maintain consistency.
Related https://developer.blender.org/T91541
@PratikPB2123 I have uploaded a diff here D14469: Fix #95604: Naming inconsistencies in alembic exporter options, please review.
Added subscribers: @HooglyBoogly, @Ujwal-Kundur, @Ethan-Hall
Perhaps a design tweak could be discussed to help prevent confusion. However, I am removing this from #good_first_issue.
Alembic exporter - name inconsistencies in the optionsto UI: Label design pattern causes confusionIn this this case the two "samples" buttons should be aligned so it's clear that they should be interpreted as a group.
@HooglyBoogly I still wish it looked a bit more elegant. How do you feel about something like this?
Split Label Proposal
{F13022822 size=full}
This design allows for splitting a label with a visual indicator to help clarify that the leading part of the label applies to both items (even if the buttons are not (or cannot be) aligned/connected)
@Ethan-Hall Looks great! How about a drop-down for the buttons which are context dependent? It would reduce visibility for a few of the options, but allows grouping attribute related buttons together.
It's an interesting idea, but personally I would rather not increase the complexity in this area, both visually and in the code. I think it looks a bit busy honestly, the alignment is a fair amount more arbitrary after with that line IMO.
I think using alignment to signify this connection more consistently would be helpful though.
