Converting object with GN modifier containing Capture Attribute node to mesh creates anonymous attributes #95613
Closed
opened 2022-02-08 13:16:43 +01:00 by Ludvik Koutny · 7 comments
Contributor
Operating system: Windows-10-10.0.19044-SP0 64 Bits
Graphics card: NVIDIA GeForce RTX 2080 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 496.76
Broken: version: 3.1.0 Beta, branch: master, commit date: 2022-02-07 22:08, hash: 229d0ace02
When converting a GN object with a modifier which uses a GN node network containing Capture Attribute node(s) into a mesh using bpy.ops.object.convert(target='MESH'), the resulting mesh contains anonymous attributes user has not intended to output.
  1. Open the attached file:
  2. Convert the cube to mesh using Object>Apply>Visual Geometry to Mesh:
    Result: The resulting mesh contains internal anonymous attributes user has not intended to output
    Expected: The resulting mesh contains only the attributes user has intended to output
    AttributeBug.blend
**System Information** Operating system: Windows-10-10.0.19044-SP0 64 Bits Graphics card: NVIDIA GeForce RTX 2080 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 496.76 **Blender Version** Broken: version: 3.1.0 Beta, branch: master, commit date: 2022-02-07 22:08, hash: `229d0ace02` Worked: (newest version of Blender that worked as expected) **Short description of error** When converting a GN object with a modifier which uses a GN node network containing Capture Attribute node(s) into a mesh using bpy.ops.object.convert(target='MESH'), the resulting mesh contains anonymous attributes user has not intended to output. **Exact steps for others to reproduce the error** 1. Open the attached file: 2. Convert the cube to mesh using Object>Apply>Visual Geometry to Mesh: ![image.png](https://archive.blender.org/developer/F12855179/image.png) Result: The resulting mesh contains internal anonymous attributes user has not intended to output Expected: The resulting mesh contains only the attributes user has intended to output [AttributeBug.blend](https://archive.blender.org/developer/F12856960/AttributeBug.blend)
Author
Contributor
Added subscriber: @Rawalanche
Member
Member
@Rawalanche Hi, probably a dumb question but I could not find GN modifier on cube. Did you upload the correct file?
Author
Contributor
Huh, that is so strange :| I am sure I did, but upon reopening I do not see it. This one should work hopefully.AttributeBug.blend
> In #95613#1304425, @PratikPB2123 wrote: > @Rawalanche Hi, probably a dumb question but I could not find GN modifier on cube. Did you upload the correct file? Huh, that is so strange :| I am sure I did, but upon reopening I do not see it. This one should work hopefully.[AttributeBug.blend](https://archive.blender.org/developer/F12856960/AttributeBug.blend)
Pratik Borhade changed title from Converting object with GN modifier containing Capture Attribute node to mesh using Convert to Mesh operator clutters resulting mesh with anonymous attributes to Converting object with GN modifier containing Capture Attribute node to mesh creates anonymous attributes 2022-02-09 12:36:12 +01:00
Member
Jacques Lucke self-assigned this 2022-02-09 17:48:31 +01:00
This issue was referenced by 25c4000796
This issue was referenced by 25c4000796833966386b125744b17ede81aa62b1
Member
Reference: blender/blender#95613
