Crash on undo #95622
2 Participants
Reference: blender/blender#95622
Graphics card: NVIDIA GeForce GTX 1080/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 511.23
Broken: version: 3.0.1, branch: master, commit date: 2022-01-25 17:19, hash:
dc2d180181
When undoing multiple times blender crashes with no warning
Open blender
Select default cube
Switch to edit mode
Select edge
Use bevel command to bevel edge with 4 segments
Switch to object mode
Set object shade smooth
Set normals Auto Smooth 30
Undo 4 to 8 times
Blender crashes, no warning message
Added subscriber: @davidmkelly
Hi, Thanks for the report. Tested with your given steps but doesn't crash on 3.0.1 (neither on latest master)
Please check again with factory settings: {nav File > Defaults > Load Factory Settings}
Thanks Pratik, after resetting to defaults, it doesn't crash. So I'm very confused. Please close this.
Hi, thanks for testing. So I suspect one of the enabled add-on is culprit.
Can you find which exact add-on caused the crash? (try disabling enabled add-on one-by-one)
That took some time :-) It appears to be the BPainter add-on by Andreas Esau. The version I have is 2.0.16, and I don't see an updated version. I'll try contact him through the blender market site. Odd because I wasn't actually using the add-on even though it was active.
Thank you for investigating. Closing the ticket because addon which causes the crash is not maintained by Blender.
Thanks again for the report
