Struct of Arrays Refactor for Mesh Polygons #95967
2 Participants
Reference: blender/blender#95967
Currently,
MPoly
stores some unnecessary data besides what is necessary:Data Format
For the reasons described in #95965, this is an inefficient way to organize data.
The first goal is to move the everything besides the face corner start index and the size to separate data layers.
Next, we can use the same offsets storage as curves to transform
MPoly
into a single integer indicatingthe offset of the first corner in the face corner domain. The size of the polygon would be the difference
between that integer offset and the next.
Array<int> poly_offsets
This pattern is abstracted with the
OffsetIndices
class in Blender. The data would be accessed in two ways:Iterating over the corners of a face is quite simple.
The only functional change this requires is that the order of the corners in a mesh is consistent with
the order of the corresponding polygons. Since this is the case in (all?) cases where new meshes are
created, it should be okay to expect this and to version meshes that don't comply.
The final result is that accessing mesh polygons will require a third of the memory that it does now.
Since they are used in hot loops where other data is accessed, that should give a sizeable improvement.
Material Index
This should move to a named integer attribute, with the name
material_index
.This means it doesn't have to be processed when there are no material indices,
and meshes with a single material can also be processed more efficiently.
f1c0249f34
Flag
In the flag is:
Selection
12becbf0df
This can be moved to a boolean custom data layer. Some way to process it differently than regular attributes will have to be implemented.
ME_SMOOTH
#93551 proposed moving this data completely to the edge domain, but in the end it is simpler to allow it to be on both edges and faces.
The flag value will be moved to a
sharp_face
attribute.ME_HIDE
2480b55f21
This can be moved to a separate boolean custom data layer, likely with a reserved name.
This issue was referenced by
2480b55f21
f1c0249f34
12becbf0df
