Shift + 1234567890 not working in Edit Mode. #96115
Reference: blender/blender#96115
Hi there!
Apparently shortcuts that use numeric keys (main keyboard) with modifier key SHIFT are not working properly in Edit Mode (at least).
The conflict is the "usual one" of the !@#$%^&*() characters not being taken as SHIFTed versions of 1234567890.
Greetings!
g
Added subscribers: @GabrielGazzan, @mont29
Hi, thanks for the report.
Are you using custom keymap or default one?
I can not reproduce at least with Select mode switching (Shift 1-3)
Removed subscriber: @mont29
Thanks for checking it Pratik.
Yes, I'm using default keymap.
I've noticed the problem while trying to use Shift + 5 (Extrude Along Normals shortcut).
Now I've also tried changing its shortcut to be just E (replacing the default Extrude Region shortcut) and, although the change seems to have taken place, when I hit E it activates the Extrude region tool, and not the suposed one.
So it seems to be another kind of issue...
Added subscriber: @mano-wii
Can you provide system information, Blender version, the last Blender version which worked, and the exact steps to reproduce the problem?
It's good to keep in mind that we need to replicate the problem in order to fix it, and the key detection system may vary by operating system and Blender version.
A guideline for making a good bug report can be found at https://wiki.blender.org/wiki/Process/Bug_Reports
sorry for not following up in time.
the problem still persists.
PC type: HP Notebook AMD A6-9225
Graphics: RADEON R4
S.O.: WIndows 10
Blender version with issue: 3.1 official release
(last version which worked: I don't really know)
Steps to reproduce:
Expected behavior: "Extrude Along Normals" is activated.
What actually happens: "Edge Crease"is activated instead.
Note: The same happens for example (as I noted above) if you try to use just "E" as shortcut. In that case, after supposedly changing the shortcut to the new tool, the tool originally assigned to "E" (Extrude Region) is really activated.
Changed status from 'Archived' to: 'Needs Triage'
Added subscriber: @pablovazquez
In this part of today's "Blender Hoy" live stream , @pablovazquez just came across this very issue with shortcuts.
He tried to redefine the Shift+A shortcut in the Node Editor to call some other command (Search Node), and although the program seemed to perform the task, when he tried to use the new shortcut, the default command for that key combination (Add Node) was executed instead of the newly assigned one (Search).
I've checked the video and I've seen similar issues mentioned other times.
What happens is a common error due to a shortcut limitation.
If two operators have the same shortcut assigned, the other operator is only executed if the first one allows
PASS_THROUGH
.In other words, there is a shortcut conflict and only one operator is executed in the case.
If you want the shortcut to work for the other operator, disable one of then.
Oh, I see... thanks for checking it.
Perhaps it would be a good idea (from a UX point of view) to issue a warning to the user, when such a case is reached (i.e. when a new assigned shortcut collides with another previously assigned).
That way at least users would know the reason for this apparent "malfunction" and could take action.
It's not that simple.
Multiple operators using the same shortcut is allowed.
Some operators are only activated under specific conditions, when not activated another operator with the same shortcut takes place.
And there are operators that allow
PASS_THROUGH
, allowing another with the same shortcut to be activated.These cases are not identifiable.
I understand Germano, thanks for the explanation.
Still, if/when technically feasible, it'd be good if users could get some cue of why a recently added shortcut would not work, although it seemed to be successfully assigned.
Greetings!
