Memory leak and design violation in curve evaluation #96498
Reference: blender/blender#96498
Operating system: Linux-5.16.0-4-amd64-x86_64-with-glibc2.33 64 Bits
Graphics card: Quadro RTX 6000/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 510.54
Broken: version: 3.2.0 Alpha, branch: Unknown, commit date: Unknown Unknown, hash:
rBUnknown
Worked: Prior to D11597
c946fdb2e5
Rendering on playing back
lib/tests/render/motion_blur/multi_step_motion_blur.blend
results in memory leak.Exact steps for others to reproduce the error
Easiest to see if LSAN is enabled, but guarded allocator also catches the issue.
Way 1: Open the file, hit F12, observe memory leak printed on exit.
Way 2: Open the file, hit playback, exit
There are two things which on a glance seems to be wrong in the new implementation (since the mentioned patch) in the
BKE_displist_make_curveTypes
.The
ob->data
at the moment of the function is called is not "localized" to the object: if multiple objects are sharing the same curve multiple copy-on-write objects will share the same copy-on-write curve. This means that writing tocow_curve.curve_eval
is "illegal". The general rule: do not write to object-data level when evaluating object. This general rule is violated without either explanation or realization that it is something bad.The freeing of
Curve::curve_eval
is only happening in thecurve_free_data
, which means evaluating same depsgraph at different times will not free this data:cow_curve.curve_eval = nullptr;
.P.S. The comment in the
Curve::CurveEval
statesOwned by the object's #geometry_set_eval
. That's the giveaway: something owned by object level can not be stored in the object-data level.Added subscriber: @Sergey
Yikes, I just realized the problem is worse than I expected. Even in 3.1, a modifier on a single curve object affects all users of the original curve. I'm amazed that behavior made it so long in master.
{F12929626 size=full}
I can relatively easily fix that problem by moving the final evaluated
CurveEval
around to a different place, but not yet without causing other problems. Maybe I'll have better luck tomorrow.Really though, I'm thinking that the easiest/best way to fix this might be just using the new curves object for rendering. That's already planned for the next week or two anyway.
Will this allow us to get rid of
CurveEval
from theCurve
datablock?Other thought to keep in mind: is this issue something we want to be fixed in possible upcoming corrective release for 3.1?
Other than that, focusing on the proper solution is surely better idea than trying to find a quicker and less ideal fix.
Yes, it would, since
Curve
wouldn't be used for rendering at all. We would just need a way to draw theCurve
edit mode overlays from theCurves
data type, which sounds a bit weird, but maybe still better than alternatives.Hmm, I don't really think so, it's a bad bug but also a tenuous situation, not an area I'd change in a corrective release.
This issue was referenced by
a7c65ef4cb
