Remesh modifier after a Geometry Nodes modifier destroys the material #96499
5 Participants
Reference: blender/blender#96499
Operating system: Win 10
Graphics card:
Broken: 3.2.0
fc259d4c30
Adding a Remesh modifier destorys the materials either coming from a geonodes material assigment or from the object's own material assignments, makes itt impossible to assign a material.
blender_z5bz6pFiOX.mp4
Load the attached .blend file
Enable and disable the remesh modifier to see what happens with the material
no_mat_15032022_1156_53.blend
Added subscriber: @kursadk
Thanks for the report. This is basically a performance tradeoff with the remesh modifier. It doesn't transfer attributes to its result.
However, this isn't noted at all in the documentation, so I'll call this a bug that can be fixed by adding that information to the manual page.
This seems to be an issue if the materials applied to at the data block rather than the object level.
Changed status from 'Confirmed' to: 'Needs Triage'
Hmm, yeah, I think I jumped to that conclusion a bit too fast. This would work if the remesh node transferred material indices, but there might be another reason it doesn't work too.
Added subscriber: @iss
From what I can see, after geometry nodes, there is no material assigned to mesh. Set Material node does assign material to faces. Therefore remesh modifier does not have any material to transfer to new mesh.
So I think the original conclusion was correct.
Changed status from 'Needs Triage' to: 'Needs Developer To Reproduce'
@HooglyBoogly hi, isn't this issue same as the other report: #93455 (Set Material Node does not reuse existing empty slot)
Added subscriber: @PJYG
I don't know if it's helping, but on the "user" side of things a quick workaround seems to be adding a second geometry node after the remesh to set the material.2022-03-18 20-08-30.mp4
Oh yes, it is! The "Set Material" node adds the material and uses
material_index=1
. The remesh modifier doesn't transfermaterial_index
, so the result uses the default value of 0.Closed as duplicate of #93455
