Regression: Overlapping face renders black in render mode #96958
Closed
opened 2022-04-01 21:28:22 +02:00 by rawee · 19 comments
Operating system: windows
Graphics card: gtx , rtx
Broken between: c4bedeb018 - 0379ddac7d
Short Description
Overlapping faces renders black in both viewport and final render (Cycles render engine)
Steps to Reproduce
  • Open attached file
  • Switch to Cycles render engine
  • Change viewport shading to render (or render as image/animation)
#96958.blend
**System Information** Operating system: windows Graphics card: gtx , rtx **Blender Version** Broken between: c4bedeb0186b - 0379ddac7d68 **Short Description** Overlapping faces renders black in both viewport and final render (Cycles render engine) **Steps to Reproduce** - Open attached file - Switch to Cycles render engine - Change viewport shading to render (or render as image/animation) [#96958.blend](https://archive.blender.org/developer/F12963255/T96958.blend) ![FOGy-XUVkAA8EQM.jpg](https://archive.blender.org/developer/F12962543/FOGy-XUVkAA8EQM.jpg)
Author
Added subscriber: @rawee-4
#96995 was marked as duplicate of this issue
#96996 was marked as duplicate of this issue
Added subscriber: @mano-wii
Thanks for the report, but could you provide a file and steps to reproduce the problem?
Also, as a suggestion, please use Help -> Report a Bug in Blender so there is complete information about the Blender version and graphics cards.
Thanks for the report, but could you provide a file and steps to reproduce the problem? Also, as a suggestion, please use `Help -> Report a Bug` in Blender so there is complete information about the Blender version and graphics cards.
Member
Member
Member
I can confirm actually. This was broken between c4bedeb018 - 0379ddac7d
@mano-wii , will you be able to bisect? Could be hard if you've old AMD GPU #95237 (AMD GPU: Crash on startup)
I can confirm actually. This was broken between c4bedeb0186b - 0379ddac7d68 @mano-wii , will you be able to bisect? Could be hard if you've old AMD GPU #95237 (AMD GPU: Crash on startup)
Pratik Borhade changed title from overlap face is black in render mode to Regression: Overlapping face renders black in render mode 2022-04-02 04:38:47 +02:00
Contributor
Added subscriber: @dupoxy
Contributor
This looks like #96475 .
It is not a good trade-off .
In #96475#1323188, @Alaska wrote:
It looks like this is a known issue. As noted in the release notes:
There can still be artifacts with rendering overlapping geometry, in some cases more severe than before. Such overlapping geometry should be removed, or have a small distance added in between.
This looks like #96475 . It is not a good trade-off . >> In #96475#1323188, @Alaska wrote: > It looks like this is a known issue. As noted in the release notes: > >> There can still be artifacts with rendering overlapping geometry, in some cases more severe than before. Such overlapping geometry should be removed, or have a small distance added in between. >
Contributor
Added subscriber: @Alaska
Added subscriber: @juang3d
IMHO this is a perfectly acceptable trade off, this is and old known problem called Z fighting, and when it was more permisible and you rendered an animation then suddenly you realized weird flickers and problems derived from this problem.
Now you identify this, and in any case this is a bad practice that should be avoided at all costs, so IMO it’s not just a trade off but nearly a feature.
IMHO this is a perfectly acceptable trade off, this is and old known problem called Z fighting, and when it was more permisible and you rendered an animation then suddenly you realized weird flickers and problems derived from this problem. Now you identify this, and in any case this is a bad practice that should be avoided at all costs, so IMO it’s not just a trade off but nearly a feature.
Member
Added subscriber: @Bhagath-Goud
Author
at 3.0.1 it not have problem
start appear black in 3.1.0
thank you very much
at 3.0.1 it not have problem ![301.jpg](https://archive.blender.org/developer/F12969790/301.jpg) start appear black in 3.1.0 ![310.jpg](https://archive.blender.org/developer/F12969792/310.jpg) ![312.jpg](https://archive.blender.org/developer/F12969795/312.jpg) thank you very much
Added subscriber: @brecht
In further analysis, this is certainly the same issue described in #96475 (Overlapping geometry shows black faces on Cycles Blender 3.1 (Ray Tracing Precision)).
Therefore:
In #96475#1323543, @brecht wrote:
This is not considered a bug currently, it's a documented trade-off of the new method.
You can see more details of this trade-off at:
https://wiki.blender.org/wiki/Reference/Release_Notes/3.1/Cycles#Ray_Tracing_Precision
In further analysis, this is certainly the same issue described in #96475 (Overlapping geometry shows black faces on Cycles Blender 3.1 (Ray Tracing Precision)). Therefore: > In #96475#1323543, @brecht wrote: > This is not considered a bug currently, it's a documented trade-off of the new method. You can see more details of this trade-off at: https://wiki.blender.org/wiki/Reference/Release_Notes/3.1/Cycles#Ray_Tracing_Precision
Closed as duplicate of #96475
7 Participants
Reference: blender/blender#96958
