Setting a manual frame range in an action is only recognized after reloading the file #96964
Closed
opened 2022-04-01 22:40:03 +02:00 by Johannes Kollmer · 7 comments
Graphics card: NVIDIA GeForce RTX 2080 SUPER/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 497.29
Broken: version: 3.1.2, branch: master, commit date: 2022-03-31 17:40, hash: cc66d1020c
In the Dope sheet it is now possible to manually set the frame range of an action. If you do that and then push the action down to the NLA editor the objects behavior does not change. Only after saving the file and reloading manual frame range can be seen.
  1. Create Object
  2. Animate Location of Object on X-Axis from frame 0 to frame 100
  3. Select the Object
  4. In the Dope Sheets N-Panel check "Manual Frame Range"
  5. Set Start to 20 and End to 60
  6. Go to Action Editor and press "push down"
  7. Scrub the timeline and see how the action is still displayed from frame 0 to 100
  8. Save file and reload it
  9. Scrub time line and see that the action is now only displayed from frame 20 to 60
Test File with first 4 steps included:
#96964.blend
**System Information** Operating system: Windows-10-10.0.19043-SP0 64 Bits Graphics card: NVIDIA GeForce RTX 2080 SUPER/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 497.29 **Blender Version** Broken: version: 3.1.2, branch: master, commit date: 2022-03-31 17:40, hash: `cc66d1020c` **Short description of error** In the Dope sheet it is now possible to manually set the frame range of an action. If you do that and then push the action down to the NLA editor the objects behavior does not change. Only after saving the file and reloading manual frame range can be seen. **Exact steps for others to reproduce the error** 1. Create Object 2. Animate Location of Object on X-Axis from frame 0 to frame 100 3. Select the Object 3. In the Dope Sheets N-Panel check "Manual Frame Range" 4. Set Start to 20 and End to 60 5. Go to Action Editor and press "push down" 6. Scrub the timeline and see how the action is still displayed from frame 0 to 100 7. Save file and reload it 8. Scrub time line and see that the action is now only displayed from frame 20 to 60 Test File with first 4 steps included: [#96964.blend](https://archive.blender.org/developer/F12963299/T96964.blend)
Added subscriber: @Lumpengnom-3
Member
Member
Member
Added subscriber: @lichtwerk
Philipp Oeser self-assigned this 2022-04-06 11:17:31 +02:00
Member
Feature Introduced in 5d59b38605
Seems to work if the Push Down is done in the NLA itself, seems to fail if the Push Down is done from the Action Editor.
bad bpy.ops.action.push_down()
good bpy.ops.nla.action_pushdown()
Difference between the two is that the NLA variant does DEG tagging of the owner and the action, whereas the Action editor variant lacks these.
Dont see a reason for this, will add them
Feature Introduced in 5d59b38605 Seems to work if the Push Down is done in the NLA itself, seems to fail if the Push Down is done from the Action Editor. bad `bpy.ops.action.push_down()` good `bpy.ops.nla.action_pushdown()` Difference between the two is that the NLA variant does DEG tagging of the owner and the action, whereas the Action editor variant lacks these. Dont see a reason for this, will add them
This issue was referenced by 4fd3d96f46
This issue was referenced by 4fd3d96f46ea4d9f30cdd9d0bc957c776b6f4e83
Member
Reference: blender/blender#96964
