subdivision surface modifier, broken. #97050
2 Participants
Reference: blender/blender#97050
Operating system: Windows-10-10.0.22000-SP0 64 Bits (it's actually windows 11)
Graphics card: NVIDIA GeForce GTX 1650/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 512.15 (certified driver)
Broken: version: 3.1.2, branch: master, commit date: 2022-03-31 17:40, hash:
cc66d1020c
Worked: 3.1
modifying a mesh breaks display of subd modifier.
add a subd modifier to any mesh
modify mesh structure (extrude, cut, anything that modifies number of vertexes)
mesh breaks
broken subdiv.mkv
Added subscriber: @Zombie
Hi, thanks for the report. Maybe same as reported here: #96845 (Regression: GPU Subdivision with mirror/Array modifier shows artifacts)
Do you have GPU subdivision disabled in 3.1? Can you reproduce there with that option enabled?: {nav Edit > preferences > Viewport > Subdivision > GPU Subdivision}
strangely enough, turning GPU subdivision off and on again got rid of the problem, i was able to work on the mesh with absolutely no artifacts with GPU subd on.
maybe it's related to the initial generation of the subd mesh?
@Zombie hi, same happens in other report- #96845 i.e. toggling GPU subdiv off and on fixes the issue but it occurs again later
Not sure. Can you upload your blend file?
Changed status from 'Confirmed' to: 'Needs User Info'
bug.blend
i copy-pasted to a new file, bug happens, turned gpu subd off, back on again, and bug is gone.
this is a freshly pasted object, but im thinking it could be a driver related bug, i iused to get a similar bug on 2.92 using subsurface scattering (geometry exploded in a similar fashion when using eevee).
Hi, thanks for the file.
Topology of both the meshes (in video and attached file) are different. So I'm not able to reproduce the issue in your file.
No, less likely a driver related bug as disabling GPU subdivision is working for you.
I don't think this is related to the one you've reported here. Best to open a separate for it.
Anyway, I'll merge your report in #96845 as both pointing to similar mesh artifacts.
Closed as duplicate of #96845
