Cycles CUDA not rendering image whilst viewport shading set to Rendered mode #97115
2 Participants
Reference: blender/blender#97115
Operating system: Linux-5.13.0-21-generic-x86_64-with-glibc2.34 64 Bits
Graphics card: NVIDIA GeForce GTX 650 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 470.86
Broken: version: 3.2.0 Alpha, branch: master, commit date: 2022-04-03 17:57, hash:
637fe6f5ff
- also 3.0.1Worked: don't know
Rendering the default cube with Cycles when one of the viewport's shading is set to Rendered, results in the "System out of GPU memory" message coming up and the render aborting.
Rendering without a viewport set to Rendered works fine, for the default cube but also for a model with a million vertices.
Added subscriber: @jack.herbert
Hi, thanks for the report. Do you see this problem in default blender scene (cube)?
Are you rendering with default render settings?: https://docs.blender.org/manual/en/latest/render/cycles/gpu_rendering.html#error-out-of-memory
Can you share your .blend file?
I don't have similar system to test so I will pass this report to someone for further investigation.
Yes, that with the default cube scene and after loading the factory preferences.
The only things I change is to select CUDA as render device, Cycles as render engine and change the viewport mode to Rendered.
Also, pausing the viewport (with the little [II] button) doesn't stop the bug from happening.
Hi, how much VRAM do you have? Did you see rise in VRAM usage when rendering the scene?
Do you get same error with Optix?
Hi! My card, the GTX 650 Ti only support Nvidia Compute 3.0 so Optix isn't an option.
It only has 1GB of VRAM, so I always thought the error message was normal and that my GPU couldn't handle Cycles. But actually, as long as I don't have the viewport in Rendered mode, it works fine, and is about 4 faster than using the CPU.
I did some testing with the default cube (8 vertices in 6s), the default Sculpting preset (24 thousand vertices in 9s) and my own model (1 million vertices in 1m08s).
In all those renders, the VRAM goes up when rendering but never fills up, at most just over 80% gets used, then it starts using the RAM.
With the default cube and the viewport set to Rendered, switching from EEVEE to Cycles makes the VRAM go from around 30% to around 70%. Pressing F12 makes it go up a little bit, about 5% more, but then the render crashes with the "System is out of GPU memory" error message
Just a wild guess, but it kinda looks like the ability to use RAM when running out of VRAM stops working if the viewport is already using it?
Hi, thanks for the information.
2GB VRAM is minimum requirement for Blender to run.
If your system is out of VRAM then I think it should use the shared memory.
This doesn't look like a bug in Blender.
Will close this report for now as tracker is only used for bugs and errors in Blender.
Feel free to comment if there is any sort of misunderstanding. Will reopen the report in that case.
Yes, makes sense to close this if my card doesn't meet the minimum requirements, and since it doesn't seem to affect anyone else (so quite likely a problem with my setup).
And anyway it's not that much of a problem, as long as I disable rendered view I can render with GPU Cycles perfectly fine.
Thanks for your time looking into it!
