Volume scatter BSDF can not show anything inside the geometry when using texture coordinate as density input. #97134
Closed
opened 2022-04-07 07:31:13 +02:00 by NXSK · 6 comments
Operating system: windows 10
Graphics card: RTX 3090
Broken: 3.1.2 stable
Volume scatter BSDF doesn't show anything inside the geometry when using texture coordinate as density input. But it can be fixed by disconnecting the output node and reconnect again.
I used a map range node to control the volume area. And I'm not so sure if it has something to do with this issue.
  1. Delete the principle BSDF node.
  2. Create a volume scatter BSDF and connect it to the volume output socket.
  3. Create a texture coordinate node, a seperate xyz node and a map range node. Use object coordinate, set the axis and the range.
  4. Plug the map range node to the density socket of the volume scatter BSDF.
Volume scatter issue.mp4
**System Information** Operating system: windows 10 Graphics card: RTX 3090 **Blender Version** Broken: 3.1.2 stable **Short description of error** Volume scatter BSDF doesn't show anything inside the geometry when using texture coordinate as density input. But it can be fixed by disconnecting the output node and reconnect again. I used a map range node to control the volume area. And I'm not so sure if it has something to do with this issue. **Exact steps for others to reproduce the error** 1. Delete the principle BSDF node. 2. Create a volume scatter BSDF and connect it to the volume output socket. 3. Create a texture coordinate node, a seperate xyz node and a map range node. Use object coordinate, set the axis and the range. 4. Plug the map range node to the density socket of the volume scatter BSDF. [Volume scatter issue.mp4](https://archive.blender.org/developer/F12980106/Volume_scatter_issue.mp4)
Author
Added subscriber: @NXSK
Member
Added subscriber: @Alaska
Member
I can reproduce the issue in Blender 3.0, but not Blender 3.1 or 3.2, but it looks like it might be related #92028 (Cycles: not updating for homogeneous to heterogeneous volume change in viewport render) (I am also unable to reproduce #92028 in recent versions of Blender)
Does updating to 3.2 help you?
Blender 3.2 Download: https://builder.blender.org/
Operating system: Linux-5.16.0-5-amd64-x86_64-with-glibc2.33 64 Bits
Graphics card: NVIDIA GeForce RTX 3060/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 510.54
I can reproduce the issue in Blender 3.0, but not Blender 3.1 or 3.2, but it looks like it might be related #92028 (Cycles: not updating for homogeneous to heterogeneous volume change in viewport render) (I am also unable to reproduce #92028 in recent versions of Blender) Does updating to 3.2 help you? Blender 3.2 Download: https://builder.blender.org/ **System Information** Operating system: Linux-5.16.0-5-amd64-x86_64-with-glibc2.33 64 Bits Graphics card: NVIDIA GeForce RTX 3060/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 510.54
Member
Member
I can confirm on 3.2
  • Open .blend file
  • Change viewport shading to rendered (Cycles engine selected): Output is correct at this stage
  • Remove last two noddle connection
  • Connect Volume scatter output with Volume of Output node
  • Change From Min value to any (say 0.3)
  • Plug Map range result in density input of Volume scatter
    #97134.blend
This looks duplicate of #92028 so I'll merge these reports.
Don't hesitate to comment if there is any misunderstanding :)
I can confirm on 3.2 - Open .blend file - Change viewport shading to rendered (Cycles engine selected): Output is correct at this stage - Remove last two noddle connection - Connect Volume scatter output with `Volume` of Output node - Change `From Min` value to any (say 0.3) - Plug Map range result in density input of `Volume scatter` [#97134.blend](https://archive.blender.org/developer/F12982626/T97134.blend) This looks duplicate of #92028 so I'll merge these reports. Don't hesitate to comment if there is any misunderstanding :)
Member
Closed as duplicate of #92028
Reference: blender/blender#97134
