Alembic export of "Only Selected Objects" with unexpected output #97275
Reference: blender/blender#97275
Operating system: Windows-10-10.0.19044-SP0 64 Bits
Graphics card: NVIDIA GeForce RTX 2080 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 472.12
Broken: version: 3.1.2, branch: master, commit date: 2022-03-31 17:40, hash:
cc66d1020c
Worked: unknown
Exporting an object with animated visibility as Alembic cache with
checked or unchecked should generate the same caches from my repro scene, but doesn't.Related task: Looks like the "selected objects" option isn't using the new depsgraph builder from https://developer.blender.org/T75936 ?
offOnly Selected Objects
on and the cube selectedblender-vis-selected-abc-houdini.blend
Added subscriber: @Michael-Heberlein
Added subscribers: @dr.sybren, @lichtwerk
Changed status from 'Needs Triage' to: 'Needs Developer To Reproduce'
There is the principle of "invisible can never be selected" in blender, so in that regard, there is some background to this, but I would assume there are better ways to deal with it in the scenario of exporting.
The object not coming back to being selected after returning from being invisible is also an issue in other contexts, so not sure if this will really be considered a bug.
@dr.sybren: what do you think?
Thanks for your answer, Philipp.
Is there a workaround that we could use in production today?
We're animating in Blender but want to use our existing Houdini lighting/rendering pipeline.
Every character should have their own collection of geometry to be exported as Alembics, including animated object visibilities.
Could we run the export operator in something like "isolated contexts" and keep the "selected objects" option off?
Alembic export uses DEG_OBJECT_ITER_BEGIN, unsure if there is a way to override context such that only own specified objects are seen there @dr.sybren ?
Own clumsy tries at this failed:
Added subscriber: @kevindietrich
quoting @kevindietrich from chat:
Added subscribers: @JacquesLucke, @Sergey
I've worked on supporting the export of invisible objects, so IMO this should work in conjunction with "only selected" as well. What @lichtwerk said is correct, there is the "invisible means deselected" rule, but there are problems with this in practice. I was aware of the impossibilities of actually keyframing visibility (because the object needs to be selected to key it, and it gets deselected when hidden), and this is another spot where this hard rule bites us in the rear.
We could work around this in functions like
ABCHierarchyIterator::mark_as_weak_export(const Object *object)
, which is the place where the selection state is tested. IMO that would be rather hacky, though.I'd rather see "hide means deselect" rule getting more flexible. That way an exporter could just temporarily disable that for the duration of the export, and the rest of the code can remain simple. This would require a change to
BKE_base_eval_flags()
, which clears theBASE_SELECTABLE
flag on invisible objects, which in turn clears theBASE_SELECTED
flag.@Sergey @JacquesLucke what would you think of something like a depsgraph evaluation option to make this little bit of code in
optional?Exporters that construct their own depsgraph (USD and Alembic, maybe more) could pass that option and work as expected, resolving this task. For the "allow animating visibility without an aneurism" issue this wouldn't be enough, and IMO that'll require a decent design task first.
@dr.sybren The problem with the proposal is that it leads to inconsistency in semantic of flags. If the piece of code is essential from the current design point of view, then after implementing your suggestion a base might be in an inconsistent state when it is selected but is not selectable. One might argue that this is OK since Alembic/USB knows what to do, but there many more stages of evaluated the object can come through. I also don't really like idea of making a precedence of semantic change depending on who cerated/evaluated a dependency graph.
Possible alternatives:
BASE_SELECTABLE
andBASE_SELECTED
. Maybe renameBASE_SELECTED
toBASE_WANTS_TO_BE_SELECTED
, and call utilityis_base_selected_for_user_interaction()
. Semantically, not literally :)NO! Your arguments are too convincing ;-)
Currently the selection state is used to determine the "export set" (i.e. which objects to export). This could be handled in a different way as well, moving the construction of the "export set" to a separate pre-export step. During the actual export the "export set" can then be used instead of the selection state.
