Blender crashes when Windows file viewer is opened #97369
Reference: blender/blender#97369
Operating system: Windows-10-10.0.22000-SP0 64 Bits (I have Windows 11)
Graphics card: NVIDIA GeForce RTX 3080/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 512.15
CPU: i7 9700K @ 4.7Ghz
RAM: 32 GB DDR4 Corsair Vengeance Pro
Broken: version: 3.1.0, branch: master, commit date: 2022-03-08 18:16, hash:
c77597cd0e
Blender crashes when Windows file viewer opens, such as, when saving files, choosing image texture.
About 50% of the time Blender will crash when file viewers is opened. I've tried many different version of Blender and all exhibit the same issue.
Every other time I chose an image texture, Blender will crash to Desktop instantly or if I go to save as.
At the same time as this issue appeared I noticed even a simple startup scene will cause 100% CPU usage when moving the camera in Material Shaded view or Render view. Even when a new shader node is added CPU will jump to 100% and Blender will stutter a bit. If the file viewer is open when the CPU is at 100%, Blender will crash to desktop.
I seem to get better results using CUDA instead of OptiX, but box exhibit the same issue.
Added subscriber: @NonSmallJohn
Blender crashes when windows file viewer is openedto Blender crashes when Windows file viewer is openedAdded subscriber: @iss
Please check if this happens with latest alpha build from https://builder.blender.org/download/daily/. If it doesn't please run file
blender_debug_log.cmd
and after crash upload created files.Can you clarify what is "Windows file viewer"? Do you mean file explorer? or do you mean file open/save dialog within Blender?
Hi, still crashing with the new daily build.
Windows Explorer is probably the better way to have explained it. Open/Save dialog, or Blender file view when selecting an image texture.
I can easily reproduce the issue if you need anything else.
Cheers
blender_debug_output.txt
blender_system_info.txt
Added subscriber: @rjg
@NonSmallJohn Please also upload the crash log located at
C:\Users\curri\AppData\Local\Temp\QuietSlopes-Town-Test.crash.txt
.Also check if this happens when you click on File > Defaults > Load Factory Settings
Still seeing the same issue with default settings.
Had the default cube with the viewport set to Rendered view, switched to Cycles renderer, rotated the camera, clicked CTRL + S to save, crash to desktop.
There are no symbols in crash file. Can you repeat steps to crash with alpha build and re-upload
file?Since with factory settings this still happens, I would guess that problem would be linked to one particular blend file. Is that correct? Can you upload problematic .blend file?
The issue happens with all my blend files. I just started a project and added am image texture to the shader graph, because I can easily cause it to crash by adding a texture image through Windows Explorer file viewer.
For the current Blender crash I changed the image texture interpolation from Linear to Closest and clicked open image, then crash to desktop.
Added text below incase you have issues:
Blender 3.2.0, Commit date: 2022-04-14 19:51, Hash
48ff456a4b
bpy.data.materials["Material.001"].node_tree.nodes["Image Texture"].interpolation = 'Linear' # Property
bpy.data.materials["Material.001"].node_tree.nodes["Image Texture"].interpolation = 'Closest' # Property
backtrace
Exception Record:
ExceptionCode : EXCEPTION_ACCESS_VIOLATION
Exception Address : 0x00007FF8315749A8
Exception Module :
Exception Flags : 0x00000000
Exception Parameters : 0x2
Parameters- [x] : 0x0000000000000008
Parameters- [x] : 0x00007FF8315749A8
Stack trace:
Loaded Modules :
0x00007FF706D50000 3.2.0.0 blender.exe C:\Users\curri\Downloads\blender-3.2.0-alpha+master.48ff456a4bda-windows.amd64-release\blender-3.2.0-alpha+master.48ff456a4bda-windows.amd64-release\blender.pdb
0x00007FF901940000 10.0.22000.527 ntdll.dll
0x00007FF9000C0000 10.0.22000.613 KERNEL32.DLL
0x00007FF8FF280000 10.0.22000.613 KERNELBASE.dll
0x00007FF900990000 10.0.22000.1 WS2_32.dll
0x00007FF900BC0000 10.0.22000.613 RPCRT4.dll
0x00007FF8FFEF0000 10.0.22000.282 USER32.dll
0x00007FF8E0F80000 tbbmalloc.dll
0x00007FF8FF250000 10.0.22000.613 win32u.dll
0x00007FF8FFEC0000 10.0.22000.1 GDI32.dll
0x00007FF8E0FB0000 tbb.dll
0x00007FF8FF010000 10.0.22000.527 gdi32full.dll
0x00007FF8FF1B0000 10.0.22000.1 msvcp_win.dll
0x00007FF8FF600000 10.0.22000.1 ucrtbase.dll
0x00007FF901850000 10.0.22000.434 ADVAPI32.dll
0x00007FF901130000 7.0.22000.1 msvcrt.dll
0x00007FF8FF8A0000 10.0.22000.556 sechost.dll
0x00007FF8E0380000 14.29.30139.0 VCRUNTIME140.dll
0x00007FF900180000 10.0.22000.593 SHELL32.dll
0x00007FF8432C0000 14.29.30139.0 MSVCP140.dll
0x00007FF900FE0000 10.0.22000.1 PSAPI.DLL
0x00007FF900930000 10.0.22000.1 SHLWAPI.dll
0x00007FF8E0370000 14.29.30139.0 VCRUNTIME140_1.dll
0x00007FF8F2190000 10.0.22000.1 dbghelp.dll
0x00007FF900DE0000 10.0.22000.120 ole32.dll
0x00007FF840DE0000 8.0.1.0 openvdb.dll
0x00007FF901470000 10.0.22000.527 combase.dll
0x00007FF8431B0000 10.0.22000.41 OPENGL32.dll
0x00007FF840910000 3.10.2150.1013 python310.dll
0x00007FF900CE0000 10.0.22000.613 shcore.dll
0x00007FF8FF7E0000 10.0.22000.1 IMM32.dll
0x00007FF83ECA0000 58.134.100.0 avcodec-58.dll
0x00007FF83E940000 58.76.100.0 avformat-58.dll
0x00007FF8E0350000 58.13.100.0 avdevice-58.dll
0x00007FF83E670000 56.70.100.0 avutil-56.dll
0x00007FF901380000 10.0.22000.1 OLEAUT32.dll
0x00007FF83E5D0000 5.9.100.0 swscale-5.dll
0x0000000070440000 1.0.28.0 libsndfile-1.dll
0x00007FF83E480000 1.20.1.0 OpenAL32.dll
0x00007FF83E350000 2.0.12.0 SDL2.dll
0x000000006ACC0000 libgmp-10.dll
0x00007FF8E0340000 libgmpxx.dll
0x00007FF8CFCA0000 tbbmalloc_proxy.dll
0x00007FF8FF950000 10.0.22000.469 SETUPAPI.dll
0x00007FF8FEB00000 10.0.22000.1 CFGMGR32.dll
0x00007FF8F9470000 10.0.22000.1 VERSION.dll
0x00007FF8F3FC0000 6.10.22000.120 COMCTL32.dll
0x00007FF8BABD0000 10.0.22000.1 AVIFIL32.dll
0x00007FF896DC0000 10.0.22000.41 GLU32.dll
0x0000000070680000 libfftw3-3.dll
0x00007FF8959D0000 3.9.100.0 swresample-3.dll
0x00007FF8FE810000 10.0.22000.1 bcrypt.dll
0x00007FF8F44B0000 10.0.22000.1 Secur32.dll
0x00007FF8B6A70000 10.0.22000.1 AVICAP32.dll
0x00007FF8F2C50000 10.0.22000.1 WINMM.dll
0x00007FF8F2080000 10.0.22000.1 MSACM32.dll
0x00007FF8959A0000 10.0.22000.1 MSVFW32.dll
0x00007FF8FC680000 10.0.22000.1 dxcore.dll
0x00007FF8FE240000 10.0.22000.556 SSPICLI.DLL
0x00007FF8FE020000 10.0.22000.71 kernel.appcore.dll
0x00007FF8FCFA0000 10.0.22000.593 windows.storage.dll
0x00007FF8FCE30000 10.0.22000.527 wintypes.dll
0x00007FF8FC5A0000 10.0.22000.120 uxtheme.dll
0x00007FF8FF130000 10.0.22000.376 bcryptPrimitives.dll
0x00007FF8FED60000 10.0.22000.1 profapi.dll
0x00007FF9011E0000 2001.12.10941.16384 clbcatq.dll
0x00007FF8F4F50000 10.0.22000.1 MMDevApi.dll
0x00007FF8FEB50000 10.0.22000.1 DEVOBJ.dll
0x00007FF8DFFA0000 10.0.22000.348 AUDIOSES.DLL
0x00007FF8FD850000 10.0.22000.1 powrprof.dll
0x00007FF8FD960000 10.0.22000.1 UMPDC.dll
0x00007FF900FF0000 10.0.22000.527 MSCTF.dll
0x00007FF8F9F50000 10.0.22000.469 AppXDeploymentClient.dll
0x00007FF8F9D40000 11.0.22000.527 urlmon.dll
0x00007FF8F9A30000 11.0.22000.593 iertutil.dll
0x00007FF8F9CF0000 10.0.22000.613 srvcli.dll
0x00007FF8FDC60000 10.0.22000.434 netutils.dll
0x00007FF83B320000 30.0.15.1215 nvoglv64.dll
0x00007FF8FB380000 10.0.22000.1 WTSAPI32.dll
0x00007FF8FE6B0000 10.0.22000.1 CRYPTBASE.DLL
0x00007FF8FE6F0000 10.0.22000.1 msasn1.dll
0x00007FF8F90C0000 10.0.22000.1 cryptnet.dll
0x00007FF8FEEA0000 10.0.22000.348 CRYPT32.dll
0x00007FF8F8E30000 10.0.22000.120 drvstore.dll
0x00007FF8FE760000 10.0.22000.120 wldp.dll
0x00007FF8FEE30000 10.0.22000.527 WINTRUST.dll
0x00007FF8FC6C0000 10.0.22000.1 ntmarta.dll
0x00007FF8FC920000 10.0.22000.41 dwmapi.dll
0x00007FF8FDBF0000 10.0.22000.1 WINSTA.dll
0x00007FF8CA970000 10.0.22000.1 dataexchange.dll
0x00007FF8F5CF0000 10.0.22000.593 twinapi.appcore.dll
0x00007FF8EAB00000 10.0.22000.282 textinputframework.dll
0x00007FF8FBF90000 10.0.22000.71 CoreMessaging.dll
0x00007FF8F9100000 10.0.22000.132 CoreUIComponents.dll
0x00007FF8F1130000 7.2.22000.1 Oleacc.dll
0x00007FF8CCFC0000 5.2.5.5 Pen_Tablet.dll
0x00007FF8C6D50000 10.0.22000.593 explorerframe.dll
0x00007FF8E95D0000 10.0.22000.527 MPR.dll
0x00007FF8E2890000 10.0.22000.1 p9np.dll
0x00007FF8E2880000 10.0.22000.1 drprov.dll
0x00007FF8E2860000 10.0.22000.527 ntlanman.dll
0x00007FF8E2840000 10.0.22000.1 davclnt.dll
0x00007FF8F96D0000 10.0.22000.613 wkscli.dll
0x00007FF8DF6C0000 10.0.22000.1 cscapi.dll
0x00007FF8FE690000 10.0.22000.1 CRYPTSP.dll
0x00007FF8FDF80000 10.0.22000.282 rsaenh.dll
0x000001653B280000 3.10.2150.1013 python3.DLL
0x00007FF8B67E0000 3.10.2150.1013 _bz2.pyd
0x00007FF8958F0000 3.10.2150.1013 _lzma.pyd
0x00007FF88ECF0000 3.10.2150.1013 _elementtree.pyd
0x00007FF867D10000 3.10.2150.1013 pyexpat.pyd
0x00007FF870BB0000 3.10.2150.1013 _ctypes.pyd
0x00007FF8CF780000 libffi-7.dll
0x00007FF83B020000 _multiarray_umath.cp310-win_amd64.pyd
0x00007FF867CE0000 _multiarray_tests.cp310-win_amd64.pyd
0x00007FF8B3AA0000 3.10.2150.1013 _socket.pyd
0x00007FF8FDAD0000 10.0.22000.282 IPHLPAPI.DLL
0x00007FF8CDF30000 3.10.2150.1013 select.pyd
0x00007FF831780000 _umath_linalg.cp310-win_amd64.pyd
0x00007FF88ECD0000 _pocketfft_internal.cp310-win_amd64.pyd
0x00007FF83AF80000 mtrand.cp310-win_amd64.pyd
0x00007FF864A50000 bit_generator.cp310-win_amd64.pyd
0x00007FF864A10000 _common.cp310-win_amd64.pyd
0x00007FF8C99E0000 3.10.2150.1013 _hashlib.pyd
0x00007FF823660000 1.1.1.13 libcrypto-1_1.dll
0x00007FF864490000 _bounded_integers.cp310-win_amd64.pyd
0x00007FF870960000 _mt19937.cp310-win_amd64.pyd
0x00007FF86D820000 _philox.cp310-win_amd64.pyd
0x00007FF867FF0000 _pcg64.cp310-win_amd64.pyd
0x00007FF8642B0000 _sfc64.cp310-win_amd64.pyd
0x00007FF8316D0000 _generator.cp310-win_amd64.pyd
0x00007FF8DC500000 30.0.15.1215 nvcuda.dll
0x00007FF8D8F20000 30.0.15.1215 nvcuda64.dll
0x00007FF8F6A30000 30.0.15.1215 nvapi64.dll
0x00007FF820D00000 7.4.1.0 nvoptix.dll
@NonSmallJohn Could you please download the .zip version of Blender from here, extract it, run
blender.exe
by double-clicking on it and test again. It seems you are using the Steam version without debug symbols.Have never used a Steam version. Always download from website.
I see there are still no Symbols available following your steps above.
interior-test.crash.txt
That's unfortunate, these symbols would provide clue at least.
One more thing that can cause issues is overclocked GPU. Can you check if your GPU is running at stock speed? Otherwise I think I am out of ideas.
I've already tried turning off the GPU overclock and CPU overclock, but still the issue remains.
The only consistent evidence is Blender will cause the CPU to jump to 100% for seemingly mundane things. Such as: opening the shader editor, clicking on a node, changing any node setting. Also clicking on something such as the materials property menu will cause 100% CPU usage. Once the CPU goes to 100%, any actions that causes the Windows Explorer/File Viewer to open will crash the program.
Thanks for update.
@NonSmallJohn Just a guess, but do you have thumbnail display enabled?
I do not.
Hi, this might be related to #62651 (Dual monitor on separate graphics card driver error)
Do you have any external device (monitor, tablet) connected to your main system?
Does this only happen when floating window is opened in render mode?
Any news on this?
