Subdivision delete my figures #97825
Closed
opened 2022-05-04 02:54:01 +02:00 by javier coronado velasquez · 9 comments
Operating system: Windows 10
Graphics card: 2gb envidia
Nombre del dispositivo LAPTOP-CHFB493Q
Procesador Intel(R) Core(TM) i5-10210U CPU @ 1.60GHz 2.11 GHz
RAM instalada 8,00 GB (7,83 GB utilizable)
Tipo de sistema Sistema operativo de 64 bits, procesador x64
Broken: 3.1.2
when a put the modifier subdivision to my figures that is deleted.
**System Information** Operating system: Windows 10 Graphics card: 2gb envidia Nombre del dispositivo LAPTOP-CHFB493Q Procesador Intel(R) Core(TM) i5-10210U CPU @ 1.60GHz 2.11 GHz RAM instalada 8,00 GB (7,83 GB utilizable) Tipo de sistema Sistema operativo de 64 bits, procesador x64 **Blender Version** Broken: 3.1.2 **Short description of error** when a put the modifier subdivision to my figures that is deleted. **Exact steps for others to reproduce the error** Based on the default startup or an attached .blend file (as simple as possible). ![Captura de pantalla 2022-05-03 195304.png](https://archive.blender.org/developer/F13050165/Captura_de_pantalla_2022-05-03_195304.png)
Added subscriber: @javicoro99
Member
Member
Member
Hi, thanks for the report.
Can you upload the system info file generated from the Help menu: {nav Help > Save System Info}
Looks identical as described in #94936 (GPU subdivision option with subdivision surface modifier collapses geometry (AMD GPU))
Does it work when you disable GPU subdivision?: {nav Edit > Preferences > Viewport > Subdivision > GPU Subdivision}
Hi, thanks for the report. Can you upload the system info file generated from the Help menu: {nav Help > Save System Info} Looks identical as described in #94936 (GPU subdivision option with subdivision surface modifier collapses geometry (AMD GPU)) Does it work when you disable GPU subdivision?: {nav Edit > Preferences > Viewport > Subdivision > GPU Subdivision}
yes, this is my sytstem info
system-info.txt
and the last solution works.
i disable GPU subdivision and all works.
yes, this is my sytstem info [system-info.txt](https://archive.blender.org/developer/F13050339/system-info.txt) and the last solution works. i disable GPU subdivision and all works.
Thanks a lot!
Thanks a lot!
and other think in blender 2.93.109.0 all work fine, whitout disable the option GPU subdivision.
Member
Hi, thanks for the file.
You're running Blender on Radeon 530 Series and not on NVIDIA GPU (mentioned in the task description).
I'm closing this duplicate of #94936
Thanks again for the report
Yes. Because GPU subdiv feature is added in 3.1: https://wiki.blender.org/wiki/Reference/Release_Notes/3.1/Modeling
Hi, thanks for the file. You're running Blender on Radeon 530 Series and not on `NVIDIA` GPU (mentioned in the task description). I'm closing this duplicate of #94936 Thanks again for the report > In #97825#1351464, @javicoro99 wrote: > and other think in blender 2.93.109.0 all work fine, whitout disable the option GPU subdivision. Yes. Because GPU subdiv feature is added in 3.1: https://wiki.blender.org/wiki/Reference/Release_Notes/3.1/Modeling
Member
Closed as duplicate of #94936
2 Participants
Reference: blender/blender#97825
