Regression: Custom split normals of hidden faces/vertices remain visible (AMD GPU) #97828
Closed
opened 2022-05-04 06:39:02 +02:00 by Etienne de la Rosa · 12 comments
Operating system: Windows-10-10.0.19042-SP0 64 Bits
Graphics card: Radeon RX 560 Series ATI Technologies Inc. 4.5.14800 Core Profile Context 22.4.2 30.0.15021.7000
Broken: version: 3,3, b73dc36859
Worked: 2.93, 7223a0348f
Caused by 2262d6c45a
As stated in the title, the custom split normals of a vertex will remain visible even when hiding said vertex.
  • On fresh default cube scene
  • Select default cube and go into edit mode
  • Enable normal display (adjust length to your liking): {nav Viewport Overlays > Normals > Display Split Normals}
  • Hide any or all vertices; the face and corner normals will hide as expected, but the split normals will remain visible.
Test File:
#97828.blend
**System Information** Operating system: Windows-10-10.0.19042-SP0 64 Bits Graphics card: Radeon RX 560 Series ATI Technologies Inc. 4.5.14800 Core Profile Context 22.4.2 30.0.15021.7000 **Blender Version** Broken: version: 3,3, `b73dc36859` Worked: 2.93, `7223a0348f` Caused by 2262d6c45a **Short description of error** As stated in the title, the custom split normals of a vertex will remain visible even when hiding said vertex. **Exact steps for others to reproduce the error** - On fresh default cube scene - Select default cube and go into edit mode - Enable normal display (adjust length to your liking): {nav Viewport Overlays > Normals > Display Split Normals} - Hide any or all vertices; the face and corner normals will hide as expected, but the split normals will remain visible. Test File: [#97828.blend](https://archive.blender.org/developer/F13050463/T97828.blend)
Added subscriber: @Yuurei
Member
Member
Pratik Borhade changed title from Custom split normals of hidden faces/vertices remain visible. to Regression: Custom split normals of hidden faces/vertices remain visible. 2022-05-04 07:07:50 +02:00
Member
Added subscriber: @lichtwerk
Member
If this is a regression, could be set to High prio (and bisected if possible).
However, on my end, I cannot reproduce this
Operating system: Linux-5.13.0-0.rc6.45.fc35.x86_64-x86_64-with-glibc2.34.9000 64 Bits
Graphics card: NVIDIA GeForce GTX 970M/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 495.44
version: 3.3.0 Alpha, branch: master, commit date: 2022-05-03 07:50, hash: `rB8e71ba12e52d`
If this is a regression, could be set to High prio (and bisected if possible). However, on my end, I cannot reproduce this ``` **System Information** Operating system: Linux-5.13.0-0.rc6.45.fc35.x86_64-x86_64-with-glibc2.34.9000 64 Bits Graphics card: NVIDIA GeForce GTX 970M/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 495.44 version: 3.3.0 Alpha, branch: master, commit date: 2022-05-03 07:50, hash: `rB8e71ba12e52d` ```
Member
So I tested this again.
Neither I'm able to reproduce when I run blender with intel iGPU.
With dedicated AMD GPU I can repro.
I'll do the bisect. Will take some time.
> However, on my end, I cannot reproduce this So I tested this again. Neither I'm able to reproduce when I run blender with intel iGPU. With dedicated AMD GPU I can repro. I'll do the bisect. Will take some time.
Philipp Oeser changed title from Regression: Custom split normals of hidden faces/vertices remain visible. to Regression: Custom split normals of hidden faces/vertices remain visible (AMD GPU) 2022-05-05 13:50:48 +02:00
Member
Will raise prio since it is a regression, bisect from @PratikPB2123 incoming...
Member
Added subscriber: @Jeroen-Bakker
Member
Sorry for the delay, just finished bisecting. This was introduced in 2262d6c45a
@Jeroen-Bakker , can you check?
Sorry for the delay, just finished bisecting. This was introduced in 2262d6c45a @Jeroen-Bakker , can you check?
Jeroen Bakker self-assigned this 2022-05-23 10:30:23 +02:00
Member
The artifact is a limitation of the workaround. There isn't enough space in the buffers to store them.
I did test if the latest windows drivers fixed the original issue and that seems to be the case for at least Polaris based cards.
Will disable commonly used polaris architectures from the work-around as a fix. (rx400 + rx500) desktop cards.
Using the latest wqhl amd drivers (22.5.1)
Graphics card: Radeon (TM) RX 480 Graphics ATI Technologies Inc. 4.5.14800 Core Profile Context 22.5.1 30.0.15021.11005
The artifact is a limitation of the workaround. There isn't enough space in the buffers to store them. I did test if the latest windows drivers fixed the original issue and that seems to be the case for at least Polaris based cards. Will disable commonly used polaris architectures from the work-around as a fix. (rx400 + rx500) desktop cards. Using the latest wqhl amd drivers (22.5.1) ``` Operating system: Windows-10-10.0.19042-SP0 64 Bits Graphics card: Radeon (TM) RX 480 Graphics ATI Technologies Inc. 4.5.14800 Core Profile Context 22.5.1 30.0.15021.11005 ```
This issue was referenced by d1340e1bb2
This issue was referenced by d1340e1bb250f6ec4b9781f4b9c5f01a9e4da9e9
Member
5 Participants
Reference: blender/blender#97828
