Regression: Material Output inside node group not working if there is a Group Output Node #98231
Closed
opened 2022-05-18 20:01:28 +02:00 by Lê Hoàng Linh · 13 comments
Operating system: Windows-10-10.0.19044-SP0 64 Bits
Graphics card: NVIDIA GeForce GTX 1060 3GB/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 512.15
Broken: version: 3.1.2, branch: master, commit date: 2022-03-31 17:40, hash: cc66d1020c
worked: 3.0.0
Caused by 7e712b2d6a
I need to swap my materials between "Eevee" and "Cycle" so I put 2 different "Material Output Node" directly in my group.
Normally, when I swap the color, the render viewport will give me real-time changing, now I have to swap "Render Engine" between "Eevee" and "Cycle" a few times to see the work.
Work well in 3.0 but not in 3.1 and 3.1.2
Workaround
  • remove the "Group Output Node" from to group and it works again.
  • Create material output node outside nodegroup. And connect BSDF output to material output node
Create a group with "Material Output Node" and "Group Output Node" in it
  • Open .blend file
  • Select sphere which has material name This work in 3.0
  • try changing input value (color): nothing updates
    Bug Report.blend
**System Information** Operating system: Windows-10-10.0.19044-SP0 64 Bits Graphics card: NVIDIA GeForce GTX 1060 3GB/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 512.15 **Blender Version** Broken: version: 3.1.2, branch: master, commit date: 2022-03-31 17:40, hash: `cc66d1020c` worked: 3.0.0 Caused by 7e712b2d6a **Short description of error** I need to swap my materials between "Eevee" and "Cycle" so I put 2 different "Material Output Node" directly in my group. Normally, when I swap the color, the render viewport will give me real-time changing, now I have to swap "Render Engine" between "Eevee" and "Cycle" a few times to see the work. Work well in 3.0 but not in 3.1 and 3.1.2 Workaround - remove the "Group Output Node" from to group and it works again. - Create material output node outside nodegroup. And connect BSDF output to material output node **Exact steps for others to reproduce the error** Create a group with "Material Output Node" and "Group Output Node" in it - Open .blend file - Select sphere which has material name `This work in 3.0` - try changing input value (color): nothing updates [Bug Report.blend](https://archive.blender.org/developer/F13087471/Bug_Report.blend)
Added subscriber: @LeLinh
Member
Member
Member
I can confirm. Finding the commit that has affected the real time update of material in viewport
Member
Member
Update in viewport is not happening since 7e712b2d6a
@JacquesLucke , can you check?
The Solution I have is to remove the "Group Output Node" from to group and it works again.
Yes, your workaround does the job in previous versions. But it's neither working after this commit 80859a6cb2
I'll open separate report for it.
Update in viewport is not happening since 7e712b2d6a @JacquesLucke , can you check? > The Solution I have is to remove the "Group Output Node" from to group and it works again. Yes, your workaround does the job in previous versions. But it's neither working after this commit 80859a6cb2 I'll open separate report for it.
Pratik Borhade changed title from "Material Output Nodes" inside node group not working if there is a "Group Output Node" to Regression: Material Output inside node group not working if there is a Group Output Node 2022-05-19 06:18:23 +02:00
Member
The current behavior is described in the is_output_node method. Will try to implement the todo comment there, with some luck that will solve the issue.
The current behavior is described in the `is_output_node` method. Will try to implement the todo comment there, with some luck that will solve the issue.
Jacques Lucke self-assigned this 2022-05-20 14:38:18 +02:00
Member
Member
It honestly seems pretty weird that a material output node can be nested inside a node group and still work, I would expect all material output nodes to be required to be on the top level.
However, maybe there's reasoning I'm missing or equally likely, it's not worth breaking existing behavior for a cleaner design?
It honestly seems pretty weird that a material output node can be nested inside a node group and still work, I would expect all material output nodes to be required to be on the top level. However, maybe there's reasoning I'm missing or equally likely, it's not worth breaking existing behavior for a cleaner design?
Member
I don't like it either, but it's not something we can break now. It's used quite a lot in practice.
This issue was referenced by 2d67b375a1
This issue was referenced by 2d67b375a15f8bb96233fc56a40be8cf545d08df
This issue was referenced by b81f1b8cf1
This issue was referenced by b81f1b8cf17196122a7203dc79f4c20c1cd9d5bf
Member
5 Participants
Reference: blender/blender#98231
