EEVEE materials show as completly black #98284
Closed
opened 2022-05-20 11:52:55 +02:00 by evk · 17 comments
Operating system: Ubuntu 18.04
Graphics card: Intel Corporation UHD Graphics 620 (rev 07)
Broken: 3.3 alpha, ae2d2c9361, master, 2022-05-18
Broken: 3.3 alpha, 08a39d32a9, master, 2022-05-10
Broken: 3.2.0 beta, 1a627d528c, master, 2022-05-19
Worked: 3.1.2, cc66d1020c, master, 2022-03-31
Worked: 3.3 alpha, e07ac34b3f, master, 2022-05-02
EEVEE materials doesn't work with some shader nodes. Result is all black.
Examples of working shaders: emission, glass BSDF, glossy BSDF, refracationn BSDF
Examples of broken shaders: Principled BSDF, Add shader, Mix shader
  • Start blender -> New file -> General
  • Load Factory Settings (Not a required step)
  • Change Viewport shading to Preview or Rendered
Default cube shows as black
  • Change render engine to Cycles
Default cube is gray/white as expected.
  • Change back to EEVEE
  • Go to shading workspace
  • Change material to DIffuse BSDF shader
Default cube turns white
  • Add "Add shader"
Default cube goes back to black
system-info.txt
**System Information** Operating system: Ubuntu 18.04 Graphics card: Intel Corporation UHD Graphics 620 (rev 07) **Blender Version** Broken: 3.3 alpha, ae2d2c936161, master, 2022-05-18 Broken: 3.3 alpha, 08a39d32a988, master, 2022-05-10 Broken: 3.2.0 beta, 1a627d528cf9, master, 2022-05-19 Worked: 3.1.2, cc66d1020c3b, master, 2022-03-31 Worked: 3.3 alpha, e07ac34b3fef, master, 2022-05-02 **Short description of error** EEVEE materials doesn't work with some shader nodes. Result is all black. Examples of working shaders: emission, glass BSDF, glossy BSDF, refracationn BSDF Examples of broken shaders: Principled BSDF, Add shader, Mix shader **Exact steps for others to reproduce the error** - Start blender -> New file -> General - Load Factory Settings (Not a required step) - Change Viewport shading to Preview or Rendered Default cube shows as black ![image.png](https://archive.blender.org/developer/F13093829/image.png) - Change render engine to Cycles Default cube is gray/white as expected. ![image.png](https://archive.blender.org/developer/F13093835/image.png) - Change back to EEVEE - Go to shading workspace - Change material to DIffuse BSDF shader Default cube turns white ![image.png](https://archive.blender.org/developer/F13093844/image.png) - Add "Add shader" Default cube goes back to black ![image.png](https://archive.blender.org/developer/F13093848/image.png) [system-info.txt](https://archive.blender.org/developer/F13093863/system-info.txt)
Author
Added subscriber: @evk
Member
Added subscriber: @lichtwerk
Member
Looks like #98128 (Regression: EEVEE: Default Cube is black on Intel), will merge reports
Member
Closed as duplicate of #98128
Author
@lichtwerk
Seems like this wasn't the same problem as in #98128 and is still present in 712b0496c1.
Can this be reopened?
@lichtwerk Seems like this wasn't the same problem as in #98128 and is still present in 712b0496c17c. Can this be reopened?
Member
Changed status from 'Duplicate' to: 'Needs Triage'
Member
Member
I'm not able to reproduce this issue.
Blender version: 3.3, 3c0d7152c89d6983db193783113387e4681e0c4d
Graphics card: Intel(R) UHD Graphics 620 Intel 4.5.0 - Build 30.0.101.1660```
I'm not able to reproduce this issue. ``` Blender version: 3.3, 3c0d7152c89d6983db193783113387e4681e0c4d Operating system: Windows-10-10.0.19043-SP0 64 Bits Graphics card: Intel(R) UHD Graphics 620 Intel 4.5.0 - Build 30.0.101.1660```
Member
Added subscriber: @Blendify
Member
@Blendify , are you able to confirm this? You've similar hardware and OS as mentioned in this report
@Blendify , are you able to confirm this? You've similar [hardware and OS ](https://wiki.blender.org/wiki/Process/Hardware_List) as mentioned in this report
Member
I could not reproduce.
renderer:	'Mesa Intel(R) UHD Graphics (TGL GT1)'
vendor:		'Intel'
version:	'4.6 (Core Profile) Mesa 22.0.1'
I could not reproduce. ``` renderer: 'Mesa Intel(R) UHD Graphics (TGL GT1)' vendor: 'Intel' version: '4.6 (Core Profile) Mesa 22.0.1' ```
Member
Added subscriber: @OmarEmaraDev
Member
Member
Is it possible for you to try a more modern version of Mesa, since you are currently running 20.0.8.
Does Blender print any error messages in the terminal when the black material appear? Running Blender from the material should give a hint.
Is it possible for you to try a more modern version of Mesa, since you are currently running 20.0.8. Does Blender print any error messages in the terminal when the black material appear? Running Blender from the material should give a hint.
Member
poke
This report reminds me #94209 but it's certainly different
> Is it possible for you to try a more modern version of Mesa, since you are currently running 20.0.8. > Does Blender print any error messages in the terminal when the black material appear? poke This report reminds me #94209 but it's certainly different
Member
Member
Thanks again for the report. If the problem persists please open a new report with the required information (or just comment here, anyone from us will reopen the ticket).
No activity for more than a week. As per the tracker policy we assume the issue is gone and can be closed. Thanks again for the report. If the problem persists please open a new report with the required information (or just comment here, anyone from us will reopen the ticket).
5 Participants
Reference: blender/blender#98284
