Btracer > Particle Trace not working in Blender 3.2.0 #98902
Closed
opened 2022-06-15 10:16:35 +02:00 by Vishnu · 9 comments
AMD 5950
Operating system: Windows-10-10.0.19044-SP0 64 Bits
Graphics card: NVIDIA GeForce RTX 3080/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 512.96
Broken: version: 3.2.0, branch: master, commit date: 2022-06-08 10:22, hash: blender/blender@e05e1e3691
Works: Blender 3.0.1
Add-on Btracer > Particle Trace not working in Blender 3.2.0
Blender version tested on: Blender 3.2.0
blender-3.2.0-stable+v32.e05e1e369187-windows.amd64-release.zip
Bug Repro Steps:
Open Blender 3.2.0
Enable the Btracer add on
Select default cube
Add particle system. Emission > Number > 20
In Layout view press n key and select Tool > Create > Btracer
Btracer > Choose Tool > Particle Trace > Settings > Curve Settings >
Spline > Bezier
Handle > Vector
Click "Add Grow Curve"
Accept defaults and click Run
Nothing happens. No particle traces occur.
This all works in Blender 3.0.1
I can open older files from 3.0.1 into Blender 3.2 and they work.
Problem > any attempts to create NEW btracer effects in Blender 3.2 won't work.
Below is error from console window:
[Btrace]
particles.particletrace: Operator
Error: SplineBezierPoints.add(): error with argument 1, "count" - Function.count expected an int type, not float
**System Information** AMD 5950 Operating system: Windows-10-10.0.19044-SP0 64 Bits Graphics card: NVIDIA GeForce RTX 3080/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 512.96 **Blender Version** Broken: version: 3.2.0, branch: master, commit date: 2022-06-08 10:22, hash: `blender/blender@e05e1e3691` Works: Blender 3.0.1 **Short description of error** Add-on Btracer > Particle Trace not working in Blender 3.2.0 Blender version tested on: Blender 3.2.0 blender-3.2.0-stable+v32.e05e1e369187-windows.amd64-release.zip Bug Repro Steps: Open Blender 3.2.0 Enable the Btracer add on Select default cube Add particle system. Emission > Number > 20 In Layout view press n key and select Tool > Create > Btracer Btracer > Choose Tool > Particle Trace > Settings > Curve Settings > Spline > Bezier Handle > Vector Click "Add Grow Curve" Accept defaults and click Run Nothing happens. No particle traces occur. This all works in Blender 3.0.1 I can open older files from 3.0.1 into Blender 3.2 and they work. Problem > any attempts to create NEW btracer effects in Blender 3.2 won't work. Below is error from console window: [Btrace] particles.particletrace: Operator Error: SplineBezierPoints.add(): error with argument 1, "count" - Function.count expected an int type, not float
Author
Added subscriber: @VR-3
#96685 was marked as duplicate of this issue
Member
Added subscriber: @lichtwerk
Member
Member
Can confirm
Can confirm
Member
Member
Added subscribers: @manfrog, @ECBuild
Pratik Borhade self-assigned this 2022-06-17 20:54:39 +02:00
This issue was referenced by b13fa85ef3
This issue was referenced by b13fa85ef34979ccd57ad8bb3e6212feb92bd9ff
Member
Reference: blender/blender-addons#98902
