Eevee: Principled volume shader set on Geonodes Volume Cube node gives unexpected result #99003
5 Participants
Reference: blender/blender#99003
Operating system: Linux 5.10.117-1-MANJARO
Graphics card: AMD ATI Radeon RX580
Broken: 3.3.0 alpha
Principled volume shader in eevee creates an additional layer of density on volumes created by Volume Cube node. Volume scatter and Volume Absorption work as expected, as does rendering on cycles. One thing of note is that the unwanted cube maintains its position when changing the bounds of the volume cube.
Create volume on geometry nodes with Volume Cube node, set density to 0. Add principled volume material with non-zero density. With appropriate eevee volumetric settings, the effect should be apparent.
smoke_bug.blend
Added subscriber: @rygelXVI
#100089 was marked as duplicate of this issue
Added subscribers: @fclem, @JacquesLucke
Can reproduce as well. No idea where that extra volume is coming from yet.
cc @fclem
Note, this is unrelated to the Volume Cube node. I can reproduce the same issue with a Points to Volume node.
Added subscriber: @mod_moder
Added subscriber: @persun
I guess EEVEE creates volume on texture space no matter what if the object has a volume shader.
An example of a simple curve object with bevel, with texture space displayed.
EEVEE renders volume based on the original mesh's texture space even if the GN output is empty.
You can also try manually remove all mesh in edit mode, EEVEE will still render default cube size volume.
